Debating on getting these ce28n's...but don't know about the fit...
Old May 14, 2007 | 06:26 AM
Spicylikcajun's Avatar
Default Debating on getting these ce28n's...but don't know about the fit...
**before anyone asks, yes i did a search and read through a lot of offset threads, none of which really answered my questions**
I found some Volk ce28n's (8 spoke) and aren't sure if I want to buy them because of the offset. I'm running a 2000 civic, koni yellow/GC combo and right now I have SI's on it, which i believe are +45 offset (correct me if i'm wrong). The Volks are +33 offset, and are 16x7, 4x100 and I'll either be running 205/40's or 205/45's on them if I buy them.
Is the +33 offset too low, and will I have to roll my fenders? And will the 205/45's be too much of a "meaty" tire? I'm want to be dropped a significant amount, approx. a 1 to a 'flush' finger gap all around. I just want to know if the Volks will be too much of a problem to hassle with...because I don't want to spend a good amount of $$ on some wheels that won't fit well.
Thanks guys.
Old May 14, 2007 | 06:31 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Debating on getting these ce28n's...but don't know about the fit... (Spicylikcajun)
+33 will stick out further than 40-45.
Lots of guys are dumped on volks. Run 205/45's you'll be fine.
You buying new or used?
Old May 14, 2007 | 06:35 AM
Default Re: Debating on getting these ce28n's...but don't know about the fit... (ek forever guy)
They are 'used' since they were mounted, but never driven on.
I know a +33 will 'stick out' farther than my SI's, but I should be safe with 205/45's? I'm not going to be running 'dumped as hell' but I'm not going to have a 2 finger gap either. I just want to be sure I'll be safe, I have some spoon calipers I've been procrastinating to put on, will the +33 clear those or no?
Old May 14, 2007 | 07:40 AM
Ek Forever y0!
Spoons will clear a 16" wheel. Expecially with that offset.
I've seen spoon calipers on 15" slips.
Old May 14, 2007 | 10:43 AM
okay, i was just worried about the offset being too low for them to clear the calipers.
will i need to roll my fenders (at all, a little bit)?
Old May 14, 2007 | 10:48 AM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spicylikcajun &raquo;</TD></TR><TR><TD CLASS="quote">okay, i was just worried about the offset being too low for them to clear the calipers.
will i need to roll my fenders (at all, a little bit)?</TD></TR></TABLE>
you def need to roll your fenders.
Old May 14, 2007 | 10:53 AM
Default Re: Debating on getting these ce28n's...but don't know about the fit... (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">
you def need to roll your fenders. </TD></TR></TABLE>
okay, that's what i figured...as long as i'll be alright after rolling the fenders i'll be fine. I just didn't want the offset to be a problem to where i'd be rubbing even if i rolled them...
sydistik
Sep 14, 2010 05:51 PM
StockDC2
Jan 24, 2009 07:29 PM
Tarmac Junkie
Nov 15, 2008 10:26 PM
t o m
13
Jan 2, 2005 05:03 PM
Mr. Vapor
Jun 6, 2002 07:36 PM
