Suspension info needed.
Old May 13, 2007 | 11:51 PM
Son99ek's Avatar
Default Suspension info needed.
i was recently trying to swap out my suspension with one from a del sol. The fronts swapped out fine with no problems. When we got to the back, the bushings for the LCA's are wider than the ones from the ek. Is it possible to swap LCA's? or is there an easier way to get around this w/o having to spend money? For example, i was thinking of sanding down the bushing to a width that the shox can clear and bolt up, would this be a bad idea?
Old May 14, 2007 | 12:03 AM
BlueIntegraBoy's Avatar
Default Re: Suspension info needed. (Son99ek)
EK struts onto a Del Sol? You'll need to shave the bushings down because EK LCAs will not bolt up to the Del Sol.
GotamaHuy
23
Apr 24, 2010 03:14 AM
94eh2
Nov 4, 2007 08:13 AM
