apex'i vafc
Old May 31, 2002 | 04:40 PM
Razor's Avatar
Default apex'i vafc
who likes theres and is it useful on a SOHC VTEC motor(f22b1). i want to lower my vtec engagement point because i dont feel like reving the motor to ~5000 rpm to hit vtec. i also heard the car preforms better when it is set around 3500. is this true?
Old May 31, 2002 | 05:41 PM
Eddiebx's Avatar
Default Re: apex'i vafc (Razor)
Hey, I just found out recently that the VTEC switch over is at like 2300-3200rpm, depending on engine conditions and load, on the 5th gen F22B1. I was flipping through the manual and noticed that the other day. So I guess if you set it at 3500rpm it would actually be raising it?
I think basically the F22B1 works like a 12-valve engine when VTEC is not engaged. Like 1 intake valve and 2 exhaust valves, and when VTEC kicks in the other intake valve starts opening. Yeah that probably has nothing to do with what your asking, but I found it interesting, hehe.
Eddie
Old Jun 1, 2002 | 09:24 AM
Gennady's Avatar
New User
Default Re: apex'i vafc (Eddiebx)
Do you know what your talking about?
Old Jun 1, 2002 | 09:28 AM
SOHCArchangel's Avatar
Eddie
WRONG
all 16 valves work all the time
3500 is what i had my cutover at, dun reit has many others have as well
anyway back to this clown that does not know what he is talking about
THE HICAM CUTOVER STOCK IS 5250
the mid lobe(locked) is used between 2500-5249
and prior to that a mixture of the idle and mid lobe are used to create an intense swirl effect to facilitate some low-end torque
Old Jun 1, 2002 | 09:29 AM
Gennady's Avatar
New User
Default Re: apex'i vafc (SOHCArchangel)
WRONG
*Wink*
Old Jun 1, 2002 | 10:29 AM
ArchAngel Sabastian's Avatar
New User
i like mine, and yes its hella useful theres all sorts a power to be made at 3500, especially if you gotten rid of the stock air/exhaust restrictions. misa has said this 100+ times.
Old Jun 1, 2002 | 10:37 AM
Nick H's Avatar
New User
and what about the f22b2 that doesn't have vtec huh...you are obviously mistaken...cuz honda wouldn't add an extra valve on this engine that just sits their and doesn't work at all...know what you are speaking of before you open your mouth no0-B!
[Modified by nickh2k1, 4:55 PM 6/1/2002]
Old Jun 1, 2002 | 12:56 PM
Razor's Avatar
Default Re: apex'i vafc (nickh2k1)
ok, so where can i buy one(for cheap)? is it useful on an automatic or what?
Old Jun 1, 2002 | 01:13 PM
Nick H's Avatar
New User
yes it will be useful regardless of the transmission...but i'm not sure if you will get a whole lot of added power by bringing the vtec engagement down to 3500 rpm's!
Old Jun 1, 2002 | 02:03 PM
Razor's Avatar
what are some of the perks that comes with the v-afc? i know you can adjust the idle so the car can warm up faster...
Old Jun 1, 2002 | 02:52 PM
CD8's Avatar
CD8
IMO the vafc wont really help such a stock situation. i think it would be best used with much more bolt-ons at least.
Old Jun 1, 2002 | 03:02 PM
New User
i dun think you can adjust the idle, basically your changing the vtec point and then it lets you correct the fuel mixture for the added air, you will need a dyno to get the best results but misa or i can give you the setup that im using now.
it lets you monitor the revs, throttle position as a %, fuel correction, pressure,vti, vto i dunno what the last 3 are lol.
Old Jun 1, 2002 | 03:11 PM
New User
Default Re: apex'i vafc (exaccord)
yes.. yes it does.
Old Jun 1, 2002 | 03:37 PM
urbantrain's Avatar
Default Re: apex'i vafc (Sabastian)
i thought the f22a's were the ones with vtec? f22b series were non-vtec??? anyways, it wouldnt matter what rpms you engage vtec at, its still going to be a slow piece of crap
get a motor swap if you want to go faster
Old Jun 1, 2002 | 03:42 PM
Gennady's Avatar
New User
Default Re: apex'i vafc (urbantrain)
F22A1, F22A4, F22A6 from the 4th gen. All non-VTEC.
F22B1 VTEC, F22B2 non-VTEC from 5th gen.
Old Jun 1, 2002 | 04:13 PM
f22b1 vtec
silly white boy,
much have yu0 to learn about the force
Old Jun 1, 2002 | 04:32 PM
New User
mmmrmm... go you must
Old Jun 1, 2002 | 05:34 PM
Eddiebx's Avatar
Ok, I said outside of VTEC the engine acts like a 12 valve. This is because one of the valves open up only enough to make sure fuel doesn't accumulate in the intake port. I might not have been clear before, I mean all 16 valves are still working, just that one of them opens slightly so thats why I said it acts like a 12 valve. I believe they did it like this so that there will be a swirling affect when the air and fuel mixture comes in at low RPM. And if you don't believe me, go open up the 1994 service manual and take a look for yourself, unless those "CLOWNS" over at honda are screwing with us too.
Eddie
Old Jun 1, 2002 | 05:37 PM
Default Re: apex'i vafc (WadZii)
Eddie is right.... for the 5th gen sohc vtec engine vtec comes in between 2300 and 2700 depending on throttle possision. if i had a digi cam i would take a pic of the cam to prove it to you people. when not in vtec only one intake valve opens fully, the 2nd one only opens enough to prevent fuel from pooling ontop of the valve. then when vtec comes in it opens both valves with slightly more lift than the one does when not in vtec. the vtec in the f22 was made for fuel ecconomy, not power. the 15 extra hp come from a better exhaust, a better exhaust manifold and a better intake system. for all of you with a ApexI Vafc. set the monitor to Vti.... vti comes on when the ECU says for vtec to come in. and 5250 for vtec is BS, even in my h22 it came in at 5000 stock. you people need to know the facts b4 you go bashing people
dont come here trying to school people with flawed info
the stock hi-cam cutover is 5250, and im not talking about the other mesly little lobes im talking about the rockers locking and the HI cam being used. VTEC is a SYSTEM of valvetrain parts, not somesort of 'EVENT'
cam switchover is an 'event' not 'VT3C' y0!
Old Jun 1, 2002 | 05:51 PM
New User
oOo? its gonna get dirty
Old Jun 1, 2002 | 05:52 PM
4doorH22's Avatar
I was wondering if the VAFC is good on B16s. The VAFC did wonders for my midrange on the H22. Just by lowering the VTEC crossover I think I gained like 18 HP at 5000 rpm. I really want a Hondata for control of the ignition maps as well.
Old Jun 1, 2002 | 05:53 PM
Eddiebx's Avatar
Dude seeing that you are pretty into your car, I am sure you have a honda service manual at home. Hows about you open it up and take a look at it. There's a great section in there explaining how VTEC works, oh my bad, I mean this "SYSTEM or valvetrain parts" works. Here, let me make it even easier for you, go to section 5 and read pages 4 through 7. I wouldn't want you to ACCIDENTALLY skip over those pages. Sorry, I don't have a scanner avaliable right now so I can't scan them in for you.
Eddie
Old Jun 1, 2002 | 05:56 PM
4doorH22's Avatar
Have you actually held a camshaft in your hand and looked at the intake and exhaust lobes? Ever taken off your valvecover and adusted your valves?
Old Jun 1, 2002 | 05:58 PM
Eddiebx's Avatar
Default Re: apex'i vafc (4doorH22)
Yeah on the H22As that VAFC works wondering in the mid range. If you take a look at some dynos on them with basically a stock setup the power dips a bit before hitting VTEC and then starts climbing. With the VAFC you can smooth that VTEC crossover significantly. Oh as far as the B16s go, i have no clue, , sorry.
Eddie
Old Jun 1, 2002 | 06:01 PM
Eddiebx's Avatar
Oh if that post was directed towards me, yeah I have plenty of times. Took off my camshafts once too, .
Eddie
