Metallic touch up paint...
Old May 13, 2007 | 08:53 PM
98savage's Avatar
Default Metallic touch up paint...
Alright, I've seen some little tubes of metallic touch up paint and the color isn't even close to what my car is. I have an OEM paintjob - Heather Mist Metallic that's been on the Accords for years. I was wondering if a spray form of the touch up paint would match to the car or if it would be just as useless as the tubes.
Old May 13, 2007 | 09:32 PM
powerflow's Avatar
Default Re: Metallic touch up paint... (98savage)
Most light metallics are not easy to get a very close match, such as your color. Touching up that type of color can be tricky. Your probably getting dark blobs where your applying the t/u because of the metallics in the paint. Its best to have a highly skilled, exp. tech do it, but if your picky refinishing would be ideal.
Old May 14, 2007 | 03:52 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98savage &raquo;</TD></TR><TR><TD CLASS="quote">Alright, I've seen some little tubes of metallic touch up paint and the color isn't even close to what my car is. I have an OEM paintjob - Heather Mist Metallic that's been on the Accords for years. I was wondering if a spray form of the touch up paint would match to the car or if it would be just as useless as the tubes.</TD></TR></TABLE>
Touch up paint on a scratch or chip is always going to be noticeable, if you want it done right, it needs to be refinished. IMO I'd rather have a scratch on my car than a scratch filled with off color paint.
Old May 14, 2007 | 06:54 AM
98savage's Avatar
Default Re: Metallic touch up paint... (WihaSi)
Well it's not that I have scratches...it is my front bumper that has taken a beating and I have no idea what happened. It started off with tiny chips and then huge ones started appearing and down on the lower grill, there is a chip that runs sideways across maybe 8 or 9 inches.
I was planning on just painting my bumpers and sideskirts black...might be the better option...
Old May 14, 2007 | 07:53 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98savage &raquo;</TD></TR><TR><TD CLASS="quote">Well it's not that I have scratches...it is my front bumper that has taken a beating and I have no idea what happened. It started off with tiny chips and then huge ones started appearing and down on the lower grill, there is a chip that runs sideways across maybe 8 or 9 inches.
I was planning on just painting my bumpers and sideskirts black...might be the better option...</TD></TR></TABLE>
Yeah if you have that many chips, it might be a good idea to go for the gold, and do it all.
Old May 14, 2007 | 09:03 AM
madcityEP's Avatar
metallic paint i ver hard to keep the same, i say paint it all if there is a lot, becuase that way the body shop or who ever does it can get a good color match.
Old May 14, 2007 | 02:53 PM
98savage's Avatar
Default Re: Metallic touch up paint... (nighthawkep3)
I'm going to just paint it myself...don't have the money to fork out on a paint job from "the pros"
Old May 14, 2007 | 04:35 PM
mike9571's Avatar
Pretty much anytime someone uses touchup paint it looks worse than it did before. Ecspecially with a metalic all the metalic will more than likely sag to the bottom. From the sounds of it you have alot of chips so just refinish it.
Old May 14, 2007 | 04:49 PM
98savage's Avatar
Default Re: Metallic touch up paint... (mike9571)
I bought some touch up from 123touchup.com or whatever the site is and it was gold. The bottle it came in had silver paint inside and when I opened it, it was gold to the touch. So I shook it up and what do you know.....gold. I asked if they sent the wrong color and they said that's the way it comes out. I was pissed...spend $40 or whatever it was.
Mr. Bojangles
Paint and Body
Mar 19, 2013 04:42 PM
FTNW
Paint and Body
Nov 12, 2010 05:02 PM
jdmturbo1127
Paint and Body
Aug 7, 2007 04:55 AM
chris10123
Paint and Body
Apr 19, 2007 07:09 PM
ek_will
Honda S2000
Apr 12, 2007 01:05 PM
