ALL motor itr
Old May 13, 2007 | 07:17 PM
eg64u's Avatar
Default ALL motor itr
well first off i dont want to get bashed for "why dont you search and what not" because i did. well here gos, what is the easiest way to get another rough 30+whp with already having aftermarket i/h/e. Well the reason i ask is, i have a usdm 2001 itr swap i have had in my 93 hatch. I have the usual i/h/e as well as a chipped p72. I am definately wanting to go all motor. But I am only wanting to achieve mid 12's low 12's 1/4 on drag radials/slicks. Oh and i want it to be reliable as it will be daily driven and also scca/autox from time to time. I am wanting you fellow ht guys/girls opinion of setups that would net me the goals i want. IM thinking i will go with skunk 2 pro series cams, skunk valvesprings, and toda cam gears with a tune to start. I really dont wnat to touch the buttom end as i have not really played with it enough to put my motor on the line from error of knowledge to install crank and plastigauging and etc. I already know how to and have put in cams/valvetrain and top end etc etc. Any help is greatly appreciated.
thanks in advance
Old May 13, 2007 | 07:38 PM
doood's Avatar
been there done that
Default Re: ALL motor itr (eg64u)
what type of i/h/e do you have?
Old May 13, 2007 | 07:52 PM
eg64u's Avatar
custom jg edelbrock with 2.5 collector, custom 2.5 exhaust with 2.5 flexpipe and just a ebay intake right now.
Old May 13, 2007 | 08:14 PM
VTEC2841's Avatar
Default Re: (eg64u)
rage header, AEM ITR 3" CAI, skunk2 pro2's, ported skunk2 IM, 65mm TB, and a mean tune.. just do the bolt ons that make the power..
Old May 13, 2007 | 08:37 PM
eg64u's Avatar
cool thanks, taht was semi on the lines of what i was thinking. what kinda of tb do you recommend or do you think i should get it MAX bored? oh and i would have to have a reliable/conservative tune. oh and vtec2841 what do you think this would net me on the dyno? thanks again guys
Old May 13, 2007 | 10:46 PM
junkyard racer's Avatar
im probably going to be doing the same. Im thinking about the TB, a good header, and most likely some rocket mx22 cams.
Old May 14, 2007 | 03:55 AM
97CWITR's Avatar
Default Re: (VTEC2841)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC2841 &raquo;</TD></TR><TR><TD CLASS="quote">rage header, AEM ITR 3" CAI, skunk2 pro2's, ported skunk2 IM, 65mm TB, and a mean tune.. just do the bolt ons that make the power..</TD></TR></TABLE>
pro2's? good advice there buddy...i wouldn't put those in an engine with anything under 12:1 comp
Old May 14, 2007 | 12:25 PM
eg64u's Avatar
97cwitr, yea i was kinda thinking that also "skunk2 pro2's" would be to much for what i need. but yea thanks for more input. Or post up similar setups and times and pics of motor and car if possible. i would love to see your setups.
thanks
Old May 14, 2007 | 12:40 PM
esohsee's Avatar
Default Re: (eg64u)
https://honda-tech.com/zerothread/1263436
Old May 14, 2007 | 01:19 PM
D-Rob's Avatar
Default Re: (esohsee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97CWITR &raquo;</TD></TR><TR><TD CLASS="quote">
pro2's? good advice there buddy...i wouldn't put those in an engine with anything under 12:1 comp</TD></TR></TABLE>
Why is this?
Because everyone else thinks so?
Pro2+'s will work fine.
- Derek
Old May 17, 2007 | 05:57 AM
eg64u's Avatar
thanks again guys/girls. i think im gonna start buying parts.
let me know more
Old May 17, 2007 | 06:11 AM
4g hatch's Avatar
you can make good power with blox b's. i think the type r throtttle body will do for your power goal. you'll need a good header like somebody already said rage. i would go with hondata,though there is alot of other tuning software out there
Old May 17, 2007 | 06:49 PM
VTEC2841's Avatar
Default Re: (eg64u)
I was about to say.. I've seen them in plenty 1.8's with less compression then you listed and worked fine and make great power
dc4teg95
Dec 18, 2010 06:38 PM
JJ's civic
May 20, 2006 09:59 AM
red civic standard
14
Nov 7, 2005 05:56 AM
Black R
Nov 27, 2003 10:55 PM
Black R
Nov 26, 2003 11:19 PM
