speedo is off
Tonight on the way home from dinner with the fam, I had my dad do 65 right next to me on the freeway. I did the same (according to my speedo) but I was pulling on him at about 4-5mph faster. I decided to do this because it seems like I'm flying by everyone when my gauge says I'm doing the speed limit. I have the stock 15" rim and tire on the car so it's not that. How do I go about fixing this?
1992 Si - Swapped H22a w/H23 5spd
What wheel/tire combo does your dad have? Also, there will be a slight variation between cars from tire wear and factory accuract tollerences (readings between x and y are considered correct)
He has whatever came with the '06 Base Civic. I seriously pass ppl left and right when I'm on the freeway. I do think that my tires are a bit....high profile for my car though. Will the "profile" make a diff?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeing1 »</TD></TR><TR><TD CLASS="quote">find a cool cop (if possible) and just ask him to radar you.</TD></TR></TABLE>
I'd rather just go get it checked out by an honest shop. If anyone is around KC, post one up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMgareth »</TD></TR><TR><TD CLASS="quote">yea, i have way to large of tires on my lude right now, and i run about 3-5 miles an hour faster when at 60+.
hmmm. sounds like my problem then. But when I do put 17's on this, how do I get the speedo to read right? Just wanting to know for future reference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NtheWorks »</TD></TR><TR><TD CLASS="quote">
hmmm. sounds like my problem then. But when I do put 17's on this, how do I get the speedo to read right? Just wanting to know for future reference</TD></TR></TABLE>
It's driven by a gear in the tranny and a gear in the VSS (vehicle speed sensor), you can't adjust it. Get the right sized tires if you want the speedo to read properly.
get a gps to see if your speedometer is accurate
mine isn't. when my speedo is at 62 my gps read my speed at 65. i have 205/50/16 tires
my 97 accord is opposite when my speedo read 65mph it is really going 63mph
use this.
http://www.miata.net/garage/tirecalc.html
you want to keep overall diameter the same if not as close as you can.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">
It's driven by a gear in the tranny and a gear in the VSS (vehicle speed sensor), you can't adjust it. Get the right sized tires if you want the speedo to read properly.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NtheWorks »</TD></TR><TR><TD CLASS="quote">you can't just get the thing recalibrated or something? </TD></TR></TABLE>
<U>It is driven by gears as already stated. </U>
How would you suggest calibrating some metal gears?....
you can use a speedo healer like on a street bike. Just get a fully adjustable one.
http://www.speedohealer.com/
Nameless Warrior
11
Nov 3, 2006 03:25 PM
hondaracin24
Aug 27, 2004 05:18 PM
