SWAY BAR HELP!
Old May 13, 2007 | 07:08 PM
grnaccord's Avatar
Default SWAY BAR HELP!
wHAT ALL DO I NEED TO PUT A SWAY ON THE REAR OF A 97 LX ACCORD BECAUSE i WAS READING IN MODIFIED MAG THAT YOU HAD TO HAVE A BUNCH OF EXTRE STUFF BESIDES THE SWAY BAR KIT.
Old May 13, 2007 | 07:38 PM
Alpinestar03's Avatar
Buy a haynes repair manual.
And you dont HAVE TO buy polyurethane bushings, the sway bar bushings and brackets should come with the sway bar kit.
If im not mistaken.
-Eric
Old May 14, 2007 | 03:16 AM
H2290's Avatar
Default Re: (Alpinestar03)
Crawl under your car and look at the sway bar. It's usually just two endlinks and you can use most of the stock parts. Whatever you can't use stock the sway bar will come with. And turn off caps.
Old May 14, 2007 | 05:00 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: SWAY BAR HELP! (grnaccord)
and what car was the mag referring to? Reason I ask is because the 92-95 and 96-00 Civic's had a potential problem with putting rear sway bars on. You could rip part of your rear subframe out depending on how stiff the sway bar was and how stiff of springs you had on the rear. And on those year Civic's the rear subframe was welded to the chassis, not bolted on like Accords so damaging that meant a costly repair. So companies started making braces and such to help strengthen the rear subframe so people could run stiffer sway bars without the worry of breaking things. The mag could have been referring to something like that, something the Accords don't need to worry about.
Old May 14, 2007 | 06:15 AM
hurleyint's Avatar
Default Re: SWAY BAR HELP! (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grnaccord &raquo;</TD></TR><TR><TD CLASS="quote">wHAT ALL DO I NEED TO PUT A SWAY ON THE REAR OF A 97 LX ACCORD BECAUSE i WAS READING IN MODIFIED MAG THAT YOU HAD TO HAVE A BUNCH OF EXTRE STUFF BESIDES THE SWAY BAR KIT.</TD></TR></TABLE>
First of all, learn how to type correctly.
Second, you need the installation kit that will come with the sway bar in order it install it. The LX does not come with a rear sway bar from the factory, so you will have to add end links, and the mounting plates that bolt to the subframe. Without these pieces, you will not be able to install the bar, as there are not any stock units to reuse.
Old May 14, 2007 | 01:15 PM
Patman's Avatar
we are sure even big 23mm eibach sway bars don't damage our sub frames or anything?
Old May 14, 2007 | 02:02 PM
gosu08's Avatar
Default Re: (Patman)
sorry to thread jack but if i get a ST rear sway for my 94 accord ex im good to go right? no need to buy extra parts is what i hear?
correct me if i am wrong.
thanks
Old May 15, 2007 | 07:47 AM
hurleyint's Avatar
Default Re: (gosu08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patman &raquo;</TD></TR><TR><TD CLASS="quote">we are sure even big 23mm eibach sway bars don't damage our sub frames or anything?</TD></TR></TABLE>
No. Ours is bolted in, and much stronger than the civic's, which is welded in. There will not be any damage caused to the subframe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gosu08 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to thread jack but if i get a ST rear sway for my 94 accord ex im good to go right? no need to buy extra parts is what i hear?
thanks</TD></TR></TABLE>
If you buy the bar brand new, it will come with an installation kit. The kit will include everything you need to install the bar.
Old May 15, 2007 | 08:50 AM
H-T Order of Merit
correct, like hurleyint said, the subframe of the Accord is much stronger than that of the Civic.
Old May 15, 2007 | 01:14 PM
Patman's Avatar
so anybody used the 23mm bar vs the TL bar to comment on price/performance?
royalrebel
Suspension & Brakes
11
Dec 19, 2008 07:19 PM
DarkBB4
Feb 1, 2006 01:16 PM
Andrew 825SM
Jul 7, 2003 01:19 PM
Vinceg99
Jan 10, 2003 10:56 AM
bw54867
Oct 14, 2002 06:51 PM
