Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Lowered my SI and now I have a problem, input needed
Old May 13, 2007 | 04:16 PM
jonebone's Avatar
Video Game Collector
Default Lowered my SI and now I have a problem, input needed
Okay well I'm running 18x8.5 wheels with a 225/40/18 tire and I just lowered my ride on Eibach Sportlines. It looks great, but there is one problem. My back passenger tire rubs on left turns that I take too agressively. Its a shame because otherwise the car would ride AND look fantastic.
It looks like the problem is two fold. One, the rear driver side wheel is cambered more than the passenger side, so this explains why the driver side does not rub. Second, I wrecked my car back in December, and the entire rear suspension was supposed to be fixed. I never noticed it before, but the rear passenger tire definitely sits out farther from the frame than the rear driver side tire. Stupid POS body shop job...
Anyways how should I fix this? These are the options I'm considering, each with their own pros and cons.
1. Buy a camber kit and intentionally camber the wheel so it doesn't rub.
Pro - No rub.
Con - Fast wheel wear.
2. Attempt to roll my fender. I've never done this before, but I hear you can do it with a heat gun and a baseball bat. If ANYONE has done this before PLEASE provide some insight on how I can do this.
Pro - No rub.
Con - Paint could crack if fender isn't rolled properly.
3. Sell the Sportlines and go with a milder drop. I don't really want to go this route because I really don't want to change springs again (not to mention I think this drop looks great).
Pro - No rub.
Con - Hassle of reinstalling and selling my Eibachs.
What do you guys think?
Here's some pics to show off the gap (my camera sucks so sorry for the crappy quality):
Old May 13, 2007 | 04:22 PM
24boosted's Avatar
Default Re: Lowered my SI and now I have a problem, input needed (jonebone)
Get coilovers and adjust the ride height difference. Add some workouot weights and bricks to the higher side of the trunk. lol
Old May 13, 2007 | 04:26 PM
VBPType-S's Avatar
believe it or not theres shops that can "professionally" roll your fenders. I guess all you can do is call around. I know of a couple shops here in vegas that roll fenders and they do a flawless job.
Old May 13, 2007 | 04:53 PM
EK4civichatch's Avatar
Default Re: (VBPType-S)
Extra camber will not wear out your tires as long as your toe is set to 0.
Old May 13, 2007 | 05:06 PM
Ouija's Avatar
Default Re: (EK4civichatch)
Camber kit.
Old May 13, 2007 | 05:15 PM
vtecmike1's Avatar
Default Re: (Ouija)
get the suspension fixed properly. its OBVIOUS that after your wreck it was not done correctly. there is NO reason one side of the car should be as it looks a whole inch lower then the other. if the suspension was done correctly you probably wouldnt rub at all. don't look for temp fixes to a greater prob.
Old May 13, 2007 | 05:22 PM
20strong's Avatar
I say get the suspension fixed properly also. Oh and danm your **** looks tight as a ****.
Old May 13, 2007 | 05:44 PM
Rahxephon's Avatar
can you get with with 215 instead of 225?
Old May 13, 2007 | 06:00 PM
Caveman74's Avatar
Default Re: Lowered my SI and now I have a problem, input needed (Rahxephon)
get the SPC camber and tweak it just a little
Old May 13, 2007 | 06:55 PM
anavrin351's Avatar
Default Re: Lowered my SI and now I have a problem, input needed (Caveman74)
take it back to the shop that didnt fix it right and make them fix it for FREE. Any half descent shop will have a gaurante
Old May 13, 2007 | 06:57 PM
onesiksohc's Avatar
Default Re: Lowered my SI and now I have a problem, input needed (anavrin351)
some shops dont wanna expletive with warrenty **** if u have one still even tho u did put that on .. its void .. u mite need a new camber ..
Old May 13, 2007 | 06:59 PM
Type X's Avatar
Told you so.
Old May 13, 2007 | 07:18 PM
exhaust_note's Avatar
looks good though.
Old May 14, 2007 | 02:49 AM
jonebone's Avatar
Default Re: Lowered my SI and now I have a problem, input needed (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">Told you so. </TD></TR></TABLE>
Yeah I was waiting for that.... but then again it definitely shouldn't have rubbed if the body shop had done halfway decent work.
I would take it back but I'm sure they'll keep my car a ridiculous amount of time (about 2 weeks I'm guessing), and probably scratch up my paint like they did last time. Not really sure its worth it if I can fix it IMO.
Old May 14, 2007 | 11:00 AM
jewjew bean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonebone &raquo;</TD></TR><TR><TD CLASS="quote"> I never noticed it before, but the rear passenger tire definitely sits out farther from the frame than the rear driver side tire. </TD></TR></TABLE>
I suppose that is because the difference in camber. I say get it fixed, dude. You're driving around in a $20k car with jacked up suspension. At least take it to an alignment shop to see what the problem is. Most places do that for free
Old May 14, 2007 | 01:02 PM
i-VTEC_DOHC's Avatar
i would go with adjustable co's.. preferrably tein..i heard cusco makes pretty good co's but idk.. hey are those nitto neo gen tires??
Old May 14, 2007 | 02:03 PM
Type X's Avatar
I would take it back but I'm sure they'll keep my car a ridiculous amount of time (about 2 weeks I'm guessing), and probably scratch up my paint like they did last time. Not really sure its worth it if I can fix it IMO.</TD></TR></TABLE>
If i was a body shop and after aftermarket rims, springs etc NOW the person if having issues. I'd send you packing.
Old May 16, 2007 | 11:59 AM
Type X's Avatar
bump 4 update?
Old May 16, 2007 | 01:56 PM
jonebone's Avatar
Well only because you asked...
I'm going to get an alignment done on my lunch break Friday (assuming they can work me in). I'll see if the condition improves any, then make my decision.
After driving about 350 miles on the suspension now, there is less rubbing. I'm guessing the wheel has cambered slightly more and now I only rub over bad bumps or real sharp left turns. However, with any additional passengers, the rub is still very noticeable.
I would have taken my car to the body shop this week and talked to the guy, but there is a NOPI event at our local track (Budds Creek) this weekend and I definitely want to be there.
We'll see what happens.
Old May 16, 2007 | 02:17 PM
Phil DeVtec's Avatar
Default Re: (jonebone)
Roll your fender...stretch tires on your wheels and drop it even more.
Old May 16, 2007 | 02:19 PM
TRE_'s Avatar
Default Re: (exhaust_note)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exhaust_note &raquo;</TD></TR><TR><TD CLASS="quote">http://www.tirerack.com/images/acces.../fenderlip.jpg
Sickness
H_s2k_H
Suspension & Brakes
Apr 24, 2012 05:26 PM
SmoothEJ8
Oct 17, 2009 08:34 PM
rydnby 4
Apr 10, 2004 09:41 PM
Uncle_Ben
Jun 27, 2002 07:53 AM
badnan
May 29, 2002 12:21 PM
