f22 flywheel/pressure plate torque specs
Hey guys done a quick search and continuing to search but cant seem to find the torque specs on and f22 for the flywheel to crankshaft bolts and need the pressure plate specs as well thanks in advance
flywheel to crankshaft torque spec = 75.9 lbs-ft
pressure plate to flywheel torque spec = 19 lbs-ft
When installing both of those, be sure to first tighten the bolts finger tight and then begin to torque the bolts down in a crisscross pattern in several steps.
Mucho thanks bro!
