problem after lowerin my accord 06
Old May 13, 2007 | 09:35 AM
nguoikhogiai2004's Avatar
Default problem after lowerin my accord 06
Hi i had been around this forum for quite along time but usually i just go take alook around 2 c how thing works and how to install etc... things. but now when i install my new TEIN to my car and drop it 2" lower, i got a prob with my wheel. it seen to be moved abit to the right, if i make it strage up again, it will turn left. like these picts:
This is Befor installation:
This is After installation:
So..if any1 has any susguession about whats wrong or wat should i do, plz reply, every susguession will be highly appreaciated and considered.
Old May 13, 2007 | 10:41 AM
02 accord's Avatar
Default Re: problem after lowerin my accord 06 (nguoikhogiai2004)
What you should do is get an alignment.
street_accord94's Avatar
you need to get an alignment.
Old May 13, 2007 | 11:43 AM
defaced8's Avatar
Default Re: (street_accord94)
Your toe end is off on your alignment, you need to take it to a shop and get an alignment.
Old May 13, 2007 | 06:07 PM
great, ty alot ppl, so all agreed with alignment needed to process in order to "get rid" of this problem. ty alot. im really appreaciate ur advice.
Old May 13, 2007 | 09:07 PM
lowered94accord's Avatar
Default Re: (nguoikhogiai2004)
alignment will do the trick..anytime you mess with your suspension like that it can throw your toe off and you will need an alignment
Old May 13, 2007 | 09:19 PM
YeuEmMaiMai's Avatar
did you install a caster kit? might want to do that......depending upon how low you are, you might need one of those.
Old May 14, 2007 | 02:56 AM
streetxdreamer's Avatar
Default Re: problem after lowerin my accord 06 (YeuEmMaiMai)
yea he said 2" drop so im thinking he will need a kit to get it into specs
Old May 14, 2007 | 08:31 PM
nope, i did not have the caster kit, beside i adjusted it 2 1.7" so that i wont have much trouble. beside, im goin to alignment it. ty for all ur advice, really apreaciate.
Old May 14, 2007 | 09:24 PM
FD's Avatar
FD
i had tein on my 7th gen too, allignment should fix that problem
05HAcc86
Jul 29, 2009 11:05 AM
The-Kid
Mar 24, 2009 11:06 AM
afg69
Jul 28, 2006 12:39 PM
localkineguy
Feb 10, 2004 09:28 PM
