throttle body and tps question
Old May 13, 2007 | 09:10 AM
classciv's Avatar
Default throttle body and tps question
my ecu is flashing a code 7 on my crx si, i think that is a tps sensor, so i tried another one that a friend had, still flashing, wires look good, it is plugged in, and now blown fuses. i found another tb with a tps off an hf, will it work for my si?
Old May 13, 2007 | 11:43 AM
91ed9's Avatar
Default Re: throttle body and tps question (classciv)
i think so i dont think there different sizes but if they bolt up it should workk
did you try adjusting the TPR sensor?
it has to be at .40-.50v at closted throttle and 5v at WOT
to test this there are 3 wires a ground , power and 5v ref
you have to put a volt meter on ground and the 5v ref
then go to closed throttle and set it to .45v (about) then tighten and then swing to WOT as see if its aroun 4.5 -5v
good luck
Old May 26, 2007 | 07:08 AM
classciv's Avatar
Default Re: throttle body and tps question (91ed9)
what about the map sensor? could that be the problem?
01_ITR
Jan 16, 2009 07:22 AM
valentine97
19
Jan 15, 2008 10:33 AM
nutball72
Nov 11, 2006 07:14 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
stehigs321
Mar 18, 2004 01:22 PM
