Burning Oil
Old May 13, 2007 | 07:15 AM
HybridBB6's Avatar
Default Burning Oil
My car has been buring oil bad in the past couple months, and I did a compression test on it and got 210 across the board. Now what could be the problems? Bad valves, headgasket?
Old May 13, 2007 | 10:11 AM
Prudz_lude's Avatar
Default Re: Burning Oil (HybridBB6)
your ringlands are gone. Time for a rebuild
Old May 13, 2007 | 11:08 AM
ludeing1's Avatar
I'd have to say the valve seals
Old May 13, 2007 | 11:29 AM
Rob97'SH's Avatar
I would also say Valve stem seals. You can watch your exhaust to see if you get blue smoke when you throttle the engine. If it was rings you would see alot of smoke all the time and your compression would be low. Its also cheaper to do the valve stem seals first.
Old May 14, 2007 | 10:15 AM
HybridBB6's Avatar
Default Re: Burning Oil (Rob97'SH)
Thank you Rob. The only time I see the blue smoke from my exhaust is when I give it a little bit of throttle.
Old May 14, 2007 | 02:36 PM
TheWalrus's Avatar
if you see smoke only when giving it throttle, id say its the oil control rings...these are the middle rings and are different than the compression rings. if it were the valve stem seals, youd see blue smoke only when you first started the car, since the oil leaked through the seals and fell in the comb.chamber while the car was off
dvd5904
74
Apr 5, 2010 05:49 AM
RacerRex
Dec 2, 2006 05:19 PM
tianporn
10
Jul 20, 2004 11:24 AM
vtec_racer_2kgsr
Jul 17, 2002 05:28 PM
