MY TURBO BUILD Pics
Old May 12, 2007 | 08:56 PM
civic95hbvtec's Avatar
Default done
not worth the time
Modified by civic95hbvtec at 9:10 AM 5/16/2007
Old May 12, 2007 | 09:53 PM
SD_Lurker's Avatar
HT White Ops
Default Re: MY TURBO BUILD 95 civic si gsr swap EVOIII Turbo PICS (civic95hbvtec)
Sweet you will have tons of fun with that bad boy!
Old May 12, 2007 | 10:37 PM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Default Re: MY TURBO BUILD 95 civic si gsr swap EVOIII Turbo PICS (SD_Lurker)
not a bad low budget build
Old May 12, 2007 | 10:58 PM
boosted timebomb's Avatar
nice ebay turbo you got there... just playin the setup looks good let us know how it holds up
Old May 13, 2007 | 05:04 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: MY TURBO BUILD 95 civic si gsr swap EVOIII Turbo PICS (boosted timebomb)
may i ask why you chose the 10w 10ohm inlines over a box? the box is so much cleaner. but thats just my oppinion. looks good so far have fun with it.
Old May 13, 2007 | 05:18 AM
m R g S r's Avatar
16g for 400+?
Old May 13, 2007 | 05:37 AM
VtecnTurbo's Avatar
Default Re: MY TURBO BUILD 95 civic si gsr swap EVOIII Turbo PICS (m R g S r)
another one joins the darkside
Old May 13, 2007 | 06:16 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic95hbvtec &raquo;</TD></TR><TR><TD CLASS="quote">Manifold and turbo are mounted. Here you can see the CUSTOM dsm manifold
made for b-series at English Racing here in Camas WA. Also you can see my
LOL. custom re-drilled ? i dont even want to see how bad the port alignment is.
Old May 13, 2007 | 06:18 AM
Jared's Avatar
maybe its just the pics, but appears that your manifold doesnt fit the head.
Old May 13, 2007 | 06:23 AM
DaveF's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">maybe its just the pics, but appears that your manifold doesnt fit the head.</TD></TR></TABLE>
check out the custom drilling you can see the original stud holes, and the new studs/holes
Old May 13, 2007 | 09:33 AM
Running925's Avatar
Default Re: (dturbocivic)
Glad to see that your doing a lot of the work here your self..
I do see a couple problems tho.. first off, that turbo and 400hp goal is not a good idea. You will see heat soak like no tomarrow.
Probly would have been a little smarter to flip the turbo around so that your charge piping didn't have to cross the hottest point of your car, this will cause some serious increase in IAT's (Intake Air Temps).
As someone else already stated.. might wanna double check your flow going from the head to the exhaust manifold.. doubting the ports line up very well.
swap your zip ties on the vacume lines out for hose clamps.. you will have much better luckt hat way.
Next time u pull your tranny.. you might wanna support the motor instead of lettin it hang like it was in the pix.. thats hell on your other mounts.. and with the added power, your going to need those mounts to be in the best condition possible.
Other than that.. get tuned & have some fun! Best of luck to ya!
Old May 13, 2007 | 10:35 AM
EG civic's Avatar
Default Re: (Running925)
[QUOTE=civic95hbvtec]
Damn it gotta pull the tranny and replace the clutch. Dont got a ton of cash
so i ordered a 6 puck XTR clutch off ebay for $140 looks ok installed it ill let ya
know how it works later.
That's good that it looks good, do u see ur clutch a lot once the tranny is installed?
Old May 13, 2007 | 10:42 AM
done
Modified by civic95hbvtec at 9:11 AM 5/16/2007
Old May 13, 2007 | 10:47 AM
DONE
Old May 13, 2007 | 01:33 PM
ultra tegboi's Avatar
Default Re: (civic95hbvtec)
just make a fairly thick heatshield for the manifold, and maybe heatwrap the pipe.
Old May 13, 2007 | 07:38 PM
GOOD IDEA
Old May 13, 2007 | 07:53 PM
SwappedTURBOegg's Avatar
lol dsm manifold and ebay turbo. youll be doing another setup shortly
Old May 13, 2007 | 10:27 PM
DONE
Modified by civic95hbvtec at 9:12 AM 5/16/2007
Old May 14, 2007 | 10:06 AM
i beg to differ.
Old May 14, 2007 | 10:56 AM
project dc2's Avatar
Default Re: (SwappedTURBOegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">i beg to differ.</TD></TR></TABLE>
agreed . you can tell by the " stamping"
Old May 14, 2007 | 11:04 AM
93supercoupe's Avatar
itll work
Old May 14, 2007 | 12:11 PM
D15Bbigred's Avatar
cough pwned cough
http://cgi.ebay.com/ebaymotors...QrdZ1
the markings on that turbo on ebay sure look similar
so before you start calling people dipshits and acting like a hardass get the facts on your own build straight.
Modified by D15Bbigred at 2:36 PM 5/14/2007
Old May 14, 2007 | 12:19 PM
awdgsx96's Avatar
What's wrong with DSM manifolds?
Old May 14, 2007 | 12:20 PM
DONE
Old May 14, 2007 | 12:35 PM
JDMs1eeper's Avatar
I think the kit looks good for when cash is low. Good luck, i like it
and BTW, ebay does not make turbos. They are an online auction.
If thats the case, I've owned 3 Ebay Civics. Woot Woot!
