FS: Civic & Turbo Stuff !!!!!!!!! (Garage Cleaning!!)
Located in SOCAL
Dont be shy to make offers but also dont be ridiculous. Everything is OBO
Shipping will cost u a bitch on large items.
i will do package deals so hit me up.
Gasket for HF manifold. Free with setup above. else $5 picked up.
Midpipe and Muffler 2.5in. This is the exhuast system i used for my setup. it was SUper quiet (2 resonators!!!!) and Super high flow as it goes under the car and not over the LCA. It sits RIGHT under the fuel tank so you dont lose much ground clearance. You will need to weld a hook on the subfame to hold up where the axleback meets the midpipe. 50 Picked UP
Brand New Autometer Mechanical Oil Pressure Guage. I only opened it up to see if it had everything, and it does. 50 obo.
Brand New Exedy Stage 2 D series Clutch kit. Now the thing is this is a repackaged kit from exedy/daikin parts so it doesnt bear the Exedy name. But if u look up Daikin you'll see that its the same as exedy. ALSO, the throwout bearing is currently for a cable D-series tranny. In order for it to work with ANY other D-series Hydro Trannies u need to buy a different throwout bearing (one for hydro), or u can add 40 to the price and i'll give u a brand new one. 250 shipped obo.
Good condition no name Steering wheel, i believe its 330mm. GOOD DEALLL $30 picked up. Steering wheel only, no horn.
2.25in midpipe for civics. 30 picked up
Resistor Box. Clean as hell. 10 picked up, 15 shipped.
Obd1/Dsm injector plugs. These are better than honda obd1 plugs cuz they can be taken off easily w.o the stupid clips. they fit obd1 injectors. 5 picked up. 10 shipped.
Si Shocks and Springs, no forks, sorry. 50 picked up
2 Ply 2.5in diameter Silicone hose that's 30 inches. that's good enough to make 10 longass couplers! or 15 of the 2inch ones. u do the math. 45 picked up.
New aluminum catch can. Baffled (has the steel whool inside). Easy to drain and hook up anywhere!! about 5in high and 2in diameter. 40 picked up
Aluminum header flange for d16... iono why u'd need this but 10 bucks picked up.
DSM sidemount intercooler 30 shipped.
99-00 Si Power Steering Unit. all you need is the rack! Best offer.
D16z6 Pistons and rods, good condition, no skirt scratching and comes with the bearings. Best Offer
Civic Shift Boot.(broken ring thing but u wont be able to tell) Free+shipping
d15b7 long block, has mostly everything in the block. Oil pan in exceptional conditon. Head is taken apart/missing stuff. Buy it for parts. Best Offer
For Trade: 15in Rota Slipstreams! Clean *** set except for one curbed wheel. They have 85-90% tires which are Falken Ziex. Right now i wanna trade for rota JSPLs or the Spun CPF copies. Or Rota Grids. I'll put in cash if your wheel is relatively worth more. I'd prefer Usable but almost worn tires.. but it doesnt matter.
Modified by Fallen86 at 1:57 PM 6/20/2007
