pops outta gear
just wondering if anyones got any suggestions
got a b16, all be cruisin on the highway and it will be in 5th gear and it will for no reason pop outta gear,
any suggestions?
any suggestions?
you might be low on fluid take the nut on the tranny off an look. if you are i recommend GM Synchromesh, i used to use honda MTF but this stuff is the best feeling **** i ever put in my tranny.
mine does it in 3rd all the time, it's your synchros or your clutch is going out.
like they said, check your tranny fluid and refill it with something good. I used redline gear oil, it's a little expensive, but it works.
Or if you have the money just send your tranny off to get the synchros carbon coated.
RTW DC2R
Sep 14, 2003 06:02 AM
