HELP: Water coming out lower vent on 94 accord
Hey my g/f has a 94 accord and recently when she takes turns whether left or right water comes pouring out of the lower center vents and gets all over the floor and on her feet. Does anyone know what is causing this? It just recently started happening. Thanks
Sounds like the drain tube for the A/C evaporator is clogged. There's a catch tray that the condensation drips into, then exits the passenger compartment via a drain tube. If the tray fills up, it will splash out as you make turns. If it recently started happening, that makes sense as you've probably just recently started using the A/C.
