EK SI Cluster into an EG
Trying to find some more info on this.. I know there is a thread on here about cutting the faces off an replacing them but I want to swap the WHOLE cluster in. I don't know if the wiring is possible or worth it, if not I'll get rid of my SI cluster an get a jdm EG cluster. Any help is appreciated, thanks!
there was a how to in the faq section of this forums, too bad the picture hosting is down. what the guy basically did was pull off the needles off both his si and eg cluster, swap the si faces over, then recalibrate the needles while driving along side his friend to get the correct reading. i was looking into then decided it was too much work and if i messed up, i would of lost both clusters.
solution: i got a eg6 cluster.
preludepower
May 14, 2012 03:17 PM
spoon_concept_eg6
Apr 4, 2008 02:15 AM
