H22 swap in 96 vtec malfunctioning
Old May 12, 2007 | 04:52 PM
galeano's Avatar
Default NO VTech
Well this is the story. My vehicle has been in the shop for bout a month. my vehicle is 96 hond accord with a h22a swap. Same accord tranny. ONly problem is that the vtech is not kicking. Where can i buy me a vtech senor for a reasonable price or what should i do.
Old May 12, 2007 | 07:03 PM
pinecone's Avatar
Default Re: NO VTech (galeano)
Are you using a P13 or P14(I forget what the h22 ecu is)? Is it wired up correctly? Check the vtec solenoid and make sure it is good shape and clean it out if need be. Do you have enough oil?
Old May 12, 2007 | 07:47 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: NO VTech (cd5_2NR)
If someone spells VTEC wrong and someone has already corrected them, I don't think we need any other posts about it. They made a mistake, they were corrected, end of story.
Old May 12, 2007 | 08:04 PM
JDM_DC4_Fanatic's Avatar
Default Re: NO VTech (TouringAccord)
to answer your question, you should check a few things first.
1) Are you running the stock prelude P13 ECU?
2) Was the proper wiring harness used/was the Vtec wired in to begin with?
3) is the vtec solenoid connected?
4) Is the sufficent oil in the engine, and is the oil any good?
Check these things first, as they are usuially the most common problems.
If all these things are in proper working order, then you may need to look into other possible problems. I worked on an Integra GSR one time, and the oil switch was reading low, when the level was up, so the ECU wouldent engage the vtec untill the pressure was high enough. Replaced the sensor, and it worked fine.
Lots of probably causes, but start with the most basic/common ones, and let us know how it goes.
Old May 18, 2007 | 05:53 PM
galeano's Avatar
Default Re: NO VTech (JDM_DC4_Fanatic)
I your are asking is the oil in the motor level is good, then yes. Or is there a seperate spot for the VTECH OIl.
They rewired it twice to make sure and test drove it for 20mins. Check engine light did not come on. I drove it for 20...when it was working felt in 4500rmp or 5000rmp. To see how the VTECH works after second run check light came on. Thought the motor was bad but the motor itself sound quite and runs pretty good. Could it be the fact i still have the accord tranny instead of the h22?
Modified by galeano at 7:41 PM 5/18/2007
Old May 18, 2007 | 07:05 PM
accord380whp's Avatar
Well one thing is for sure , is the transmission has nothing to do with your problem . F or h series transmissions do not affect this, and if your not getting the vtec after it was working . Also you might have another issue causing the vtec not to work , the vtec needs the mph,rpm,map,tps, and something else thats on the tip of my tongue . Wellanyway . if one of the five isnt working the vtec isnt going to work , It needs to read those five to work, So say your rpm guage isnt working , well then you have no vtec. But if your not getting a check engine light then it sounds like you might not have enough oil pressure. Or a wire might be messed up . I would keep taking it back to the person that preformed the swap and tell them to fix it . Theres no way you could have mucked it up unless your under the hood playing with things. Man thats bothering me what th fifth thing was that the ecu needs to read for the vtec. mph,rpm,cps,tps,map . there you go
Old May 18, 2007 | 07:37 PM
japspecb7's Avatar
maybe the oil psi sensor is bad. the green plug next to the solenoid,
Old May 18, 2007 | 07:59 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">If someone spells VTEC wrong and someone has already corrected them, I don't think we need any other posts about it. They made a mistake, they were corrected, end of story. </TD></TR></TABLE>
darn i was just about to pull a typical HT move, and post a pic of a telephone
regarding the question at hand, since you said that vtec worked, but then doesn't work after throwing a CEL, i would pull the CEL and then report back. this will help narrow down your problem.
Old May 18, 2007 | 08:15 PM
leoverte's Avatar
Default Re: NO VTech (accord380whp)
would this be the same case for my 99 accord just swapped to a manual from auto. You say five things..well my speedo is not working right now, so could that be the case why i dont feel any kick round 4 to 5 grand?? I do have cel light lite right now and i will be checking this Sunday with scanner. ANY HELP greatly needed. thanks...
Old May 19, 2007 | 10:44 AM
Eddiebx's Avatar
Default Re: NO VTech (leoverte)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leoverte &raquo;</TD></TR><TR><TD CLASS="quote">would this be the same case for my 99 accord just swapped to a manual from auto. You say five things..well my speedo is not working right now, so could that be the case why i dont feel any kick round 4 to 5 grand?? I do have cel light lite right now and i will be checking this Sunday with scanner. ANY HELP greatly needed. thanks...</TD></TR></TABLE>
yes if the ecu is not getting a VSS signal, it will not engage vtec, so that is quite possible that the VSS is the culprit in ur situation
Old May 19, 2007 | 01:05 PM
Hiii Im TYLER's Avatar
why don't you see what codes are being thrown and then you can look it up. booyah!
Old May 19, 2007 | 01:11 PM
galeano's Avatar
Default Re: (japspecb7)
Appreciate your advise, i just recently use my buddy scanner now there is no code readin from the check engine light. what the fudge. Now im completel y lost.
Old May 19, 2007 | 05:13 PM
leoverte's Avatar
Default Re: NO VTech (Eddiebx)
thanks man. We already checked the VSS manual by hooking it up to another car and turning it with a drill, and it worked fine. So we figured that the VSS is ok, but that was before i got the manual ECU coded to the keys. Tommorrow i will trouble shooting some more. thanks again man...anything else would be greatly apprceiated... and yes i suck at spelling.
Old May 19, 2007 | 05:14 PM
leoverte's Avatar
Default Re: NO VTech (JDM602)
going to try that tommorrow. thanks man.
Old May 19, 2007 | 05:30 PM
Dmc1's Avatar
The fifth thing is ECT.
Old May 21, 2007 | 04:06 PM
galeano's Avatar
should i consider removing the govenor. where can i get h22 tranny for good price.
cgaleema
Sep 11, 2011 03:42 PM
RooSter
Nov 22, 2007 04:31 PM
VolkswagenWHO!!!
Dec 1, 2006 07:09 AM
dre23
Nov 13, 2005 12:35 PM
TRE_
Jan 3, 2003 10:14 AM
