Trouble after changing spark plugs
Old May 12, 2007 | 04:20 PM
Locc's Avatar
Default Trouble after changing spark plugs
i change my spark plugs to ngk irdiums today, it started to drive fine but after 15-20 min my car starts bogging in 3 and 4th gear. Any idea whats going on ?
Old May 12, 2007 | 04:22 PM
migs's Avatar
Default Re: Trouble after changing spark plugs (Locc)
Are the plug wires secure?
Old May 12, 2007 | 04:25 PM
Locc's Avatar
Default Re: Trouble after changing spark plugs (migs)
yea its secure tight
Old May 12, 2007 | 07:12 PM
vtec.dc2's Avatar
check gap, are you using oem wires?? are you using the right plugs and make sure they're not backing out. pull spark plugs and check for correct gap..
1. i use anti sieze on threads
2. i turn it with torque wrench till 13-13.5 ft/lb or whatever the specs i think i got it right
3. i add a bit of dialectric grease on all connections
your wires might be too old, check cap/rotor as well
delsolo95
Jun 13, 2011 06:15 AM
Rtboy10
Sep 22, 2009 08:20 PM
b16b18
Sep 6, 2006 12:56 PM
DBrasco
Oct 2, 2002 11:44 AM
Seedc2
Oct 25, 2001 06:59 PM
