cleaning gunk off plastic dashboards?
Old May 12, 2007 | 03:30 PM
aTrOcIoUs's Avatar
Default cleaning gunk off plastic dashboards?
Hello i have some very sticky **** stuck to the dashboard on my car. whoever installed the window b4 i got it used some sorta caulking and its leaked onto the plastic on my dash and the plastic around the windshield. . .what would be good to use to get this crap off ive tried simple green it seemed to just smear it around even after scrubbing the **** out of it. also it will not seem to dry up and harden like most things do it stays sticky and in a gel sorta form.
pls help if anyone has any ideas i was thinking maybe acetone or paint thinner dont wanna expletive anything up tho. . .
Old May 12, 2007 | 04:51 PM
aTrOcIoUs's Avatar
Default Re: cleaning gunk off plastic dashboards? (aTrOcIoUs)
anyone a reply pls? im sure someone here has had gunk on theyre dashboard what is good to clean this stuff off any info would be appreciated
Old May 12, 2007 | 05:02 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
This is what I use (de-solv-it), to remove adhesive type stuff:
http://www.orange-sol.com/household/index.html
I normally use one towel with the cleaner, and a separate clean towel and alternately wiping to remove the adhesive. After the adhesive is removed, I wipe it down with water, just in case, so nothing else is remove from any residual cleaner.
Old May 12, 2007 | 05:46 PM
aTrOcIoUs's Avatar
Default Re: cleaning gunk off plastic dashboards? (tech8)
Thank you exactly the advice i could use ill give this stuff a try. i figured there was something worthy other then acetone or paint thinner. what a brainfart idea that would have been.
thnks tech
Old May 12, 2007 | 09:46 PM
crxcess's Avatar
could always try some denatured alcohol. every lowes or home depot will have it.
heyimrchills
Sep 18, 2009 11:43 PM
cilvia
26
Feb 7, 2006 06:48 PM
.random
Dec 1, 2005 11:15 PM
Audio28
Jan 8, 2003 07:41 PM
94LSTEG
Jul 14, 2001 10:13 AM
