hmmmm.. spark plug gap suppose to be 1mm?
So i just realized the spark plug gap is suppose to be 1.0mm....(i got a 99 accorD)
i've been driving around for 3k miles...since i change my spark plugs I put a gap of .44mm, cause that was what I assumed... (civics, integra) . Does it mean because of the smaller gap, I probably was burning richer that normal? I wonder if this have anything to do with my CEL (o2 sensor high voltage) .. high voltage because it senses burning rich
1.1 mm is pretty much standard; it is the last 2 digits of the NGK plug number IE ZFR5F11
the larger gap gives a better spark size and burn time.
I'd guess it is worth the time and effort of resetting the gap to see if it clears the code.
RACEPAK
Sep 21, 2005 04:08 AM
