odometer has stoped working!
I have a 94 honda accord lx, the odometer has stoped working but the speedometer workds fine! arent they both working off the same sensor (vss) or is that only for the speedomoter? any idea where to start looking to fix this problem?
thanks
thanks
hello I had the same problem not sure how good you are with the wrench or screw driver i removed the speedo cleaned it with the can of compressed air mad sure all the screws were not loose i belive the true reason was the screws were loose causing a bad connection to the odometer if you do attemped removing it your self becarful some hidden screws in dash two or three ele conectors and its out hope that helped you tarponhunter out
Ddunnusmc
Aug 12, 2017 05:05 PM
Lonely_Driver
Apr 4, 2003 07:04 PM
