OIL!
Old May 12, 2007 | 05:22 AM
schpiel's Avatar
Default OIL!
How much oil should you put in a B20 Vtec when you are changing the oil?
Old May 12, 2007 | 06:14 AM
Padawan's Avatar
Darth ModerVader
Default Re: OIL! (schpiel)
4.0 quarts is the spec for the B20, and 4.2 quarts is the spec for the VTEC motors. I would suggest filling with 4 quarts, running the engine briefly, and then using the dip stick to determine the exact level as you add small amounts. I always recommend slightly under-filling and then using the dipstick rather than adding one specific amount, so that you will be guaranteed to end up with the proper level.
Old May 12, 2007 | 07:11 AM
schpiel's Avatar
Default Re: OIL! (Padawan)
When you say running it briefly, do you mean like not letting it get to operating temp, but just allowing the oil to move around?
Old May 12, 2007 | 07:12 AM
Padawan's Avatar
Darth ModerVader
Just long enough so the oil circulates and fills the filter is fine.
Old May 12, 2007 | 07:13 AM
Luserkid's Avatar
Run it until you see the oil light turn off or if you have an oil pressure gauge, til it reaches full oil pressure.
KidAccord
Apr 19, 2013 06:58 PM
justinwallen12345
Mar 4, 2012 09:53 AM
highwhey
Nov 11, 2010 05:53 AM
v8killaz
Nov 20, 2009 03:21 PM
itr501
Oct 23, 2001 02:41 PM
