Which Harness is Best for LSVtec? 97 Ek???
So the situation is as follows:
Recently swapped an LS Vtec into my 97 Civic- I will be using a P28 ECU w/(Hondata Jumper obd2 to obd1)
My stock DX harness is destroyed so I plan to just buy a new engine harness.
No matter what harness I use I will have to modify however some are better/worse than others.
Any recommendation will be helpful as to what harness I should use as a starter.
DX? (Will have to wire in Vtec Solenoid and Vtec Oil PSI)
EX? (I think this would be my best bet but I am not sure)
SI? (Next best geuss however only has 1 o2 sensor)
Any input will be appreciated.
Thanks
Thanks
Unphzd
18
Aug 24, 2010 07:25 PM
2drh22
Jun 4, 2009 09:11 AM
honda_hackett
Mar 31, 2009 06:03 AM
