rear disc
just got rear discs put on since i needed new rear drums..even though its too late..are these disc brakes hurting/slowing me down any....ive got a 92 VX eg hatch.....thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VXh22eg »</TD></TR><TR><TD CLASS="quote">just got rear discs put on since i needed new rear drums..even though its too late..are these disc brakes hurting/slowing me down any....ive got a 92 VX eg hatch.....thanks</TD></TR></TABLE>
what are they off of? the rear discs are going to help you out alot. are you upgrading your MC/booster or prop vavle? The only reason that i find a rear discs being bad for you is adding more weight. I'm not sure about the EG's but on EJ8's the switch from rear drums to integra rear discs (which i have) is 7 lbs added onto each side.
i think they are off of a newer si..but i will find out...i had the new MC from a 91 ex sedan but the pedal feel is just fine with me for now so i got my 80$ back..as for the prop valve the one that i got with the swap leaks a little so for right now i just hope i dont have to lock them up cause all it does is take the back to the side.
