Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
"break-in" for my si
Old May 11, 2007 | 11:01 PM
lmfdjtiko's Avatar
Default "break-in" for my si
i just bought my si in LA yesterday and drove 4 hr back to Las vegas (where i live) mostly under 3500 rpms ,now the mileage is 500, this is my first car, and my friend say i should "break-in" the car, i dunno much about it, should i just shift under 3500 until the mileage get the 1000? what should i do?
Old May 12, 2007 | 12:05 AM
dh's Avatar
dh
Default Re: "break-in" for my si (lmfdjtiko)
https://honda-tech.com/zerothread?id=1924083
Old May 12, 2007 | 12:22 AM
SMoLiK's Avatar
The honda website says the break in period is 600 miles and I have heard not to drain the oil till the percentage is down to 15% or so...
SMo'
Old May 12, 2007 | 07:31 AM
WILD_WILL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmfdjtiko &raquo;</TD></TR><TR><TD CLASS="quote">i just bought my si in LA yesterday and drove 4 hr back to Las vegas (where i live) mostly under 3500 rpms ,now the mileage is 500, this is my first car, and my friend say i should "break-in" the car, i dunno much about it, should i just shift under 3500 until the mileage get the 1000? what should i do?</TD></TR></TABLE>
Your Si is now broken in now go vtec to your eyes bleed use it they way it should be used good luck
Old May 12, 2007 | 07:45 AM
MONTELIOUS's Avatar
congrats on the new car, maybe will see you around town sometime.
break in period is 600 miles, so take a short drive up to indian springs and back and let the vtec begin
if you have any questions about service and things like that PM FBPSidan he works at findlay-shack honda.
Old May 12, 2007 | 08:20 AM
dirtySOHC's's Avatar
Default Re: (MONTELIOUS)
this should be in a FAQ sticky or something.
break it in hard and fast....that's how they like it.
Old May 12, 2007 | 08:29 AM
THE ONE's Avatar
It also says to not keep revs constant for a long period of time. If you drive on the hwy, just push on it for a bit every few min.
Old May 12, 2007 | 08:41 AM
NavyFlip's Avatar
Default Re: (dirtySOHC's)
nice
Old May 12, 2007 | 10:23 AM
anavrin351's Avatar
Default Re: (20ls01)
i was told at the dealer if i spend alot of time on the freeway at first to vary the speed. dont no why, but i did it.
Old May 12, 2007 | 10:32 AM
FBPSidan's Avatar
Default Re: (anavrin351)
congrats on the car! Nice to see another one in town. You need anything lemme know... i know people. hah
Old May 13, 2007 | 01:13 PM
hondamanforlife's Avatar
Default Re: (FBPSidan)
break in!!! whats that??? drive it like you stool it
Old May 13, 2007 | 04:33 PM
SMoLiK's Avatar
Default Re: (hondamanforlife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanforlife &raquo;</TD></TR><TR><TD CLASS="quote">break in!!! whats that??? drive it like you stool it</TD></TR></TABLE>
stool huh... yea' listen to this guy...
SMo'
Old May 14, 2007 | 11:55 AM
SIR-G's Avatar
Do what the manual says break in for the first 600 miles
Old May 15, 2007 | 07:59 AM
Default Re: (SMoLiK)
SMo' im sorry I was born stupid and cant spell but I try! im sorry if I hurt you in anyway!!!
Old May 15, 2007 | 08:12 AM
97Ej6's Avatar
Break in is 600 miles like everyone else said however you are not to keep it at constant RPMs during the break in so dunno if that ride home would of messed you up...
Old May 15, 2007 | 11:51 AM
Tam N's Avatar
Seriously...where are people getting this from?!?!
Honda Method
600 mile break in period, refrain from WOT acceleration, hitting your redline.
Other Methods for comaprison
Originally Posted by Team-Integra.net
Use 0-30, or 5-30, or 10-30 motor oil and a Honda filter. Do NOT use synthetic motor oil for break in.
Make sure the fluid levels are where they should be. Start it up and keep the engine at 2500 -3000 rpm for about 20 minutes. Make sure there are no leaks, or mechanical problems. The only idling will be for setting the timing.
Before doing the schedule, remember that running the engine at steady rpm (like cruising on the freeway) is not good for break-in.
METHOD 1: Endyn Way
0-200 miles ( 0-325 km ) : Try to keep the highest rpm under 3000 rpm. Every 15-20 miles, zing the engine to 4500 rpm in first and occasionally in second gear.
201-400 miles ( 326-650 km ): Try to keep the revs limited to 3500 rpm. Raise the "zing" rpm to 5500 with the same frequency as above.
401-600 miles ( 651-970 km ) : Go to 4000 rpm for driving limit. Raise the "zing" to 6000 - 6500 rpm and include 3rd gear pulls, same frequency.
600-800 miles ( 971-1290 km ): 4500 rpm driving limit. "Zing" it to 7000+ rpm and include partial 4th gear pulls.
800-1K miles ( 1291-1615 km ) : 5000 rpm limit with "zing" to 7500+ rpm with some pulls all the way through 4th and partial fifth gear pulls.
Now, don't misunderstand me on the zings. You don't HAVE to scream the engine religeously at the prescribed intervals. If you don't have the space to run the engine up in the selected gears, don't do it. Just know that you can, and IF the opportunity comes around lay into it. Don't over-do the procedure.
I recommend that the oil be changed at the 1K mile marker. If the plugs are looking good and if the compression's (and leak down numbers) good, switch to Mobil 1 for life. Use either 0-30, or 10-30.
After the oil change, you might want to reset the valves and from that point on, drive it the way you'd normally run it.
METHOD 2: 2000 NIRA Comp4 Class Champion, Stephen Sakai's Way
1: Let the motor idle for about 30 minutes then change the oil.
Then take it out and road test for short distances until you reach about 100 miles. Then change the oil again.
Once you reach about 100 miles it should be broken in by then. Change the oil at 250, 500 and 1000 and then normal from then on. If you are scared you can wait until 500 miles before you start beating on it.
2: With respect to breaking in new cams : As long as you lubricated the cams properly on installation, there is no real break-in procedure.
METHOD 3: Ken Wood's (from Temple of VTEC's FAQ Section) Way
1. Use regular oil, not synthetic, during break-in.
2. When you first start it up, let it COMPLETELY warm up, not just kinda warm, all the way warm.
3. While it's still hot, check and see if the head needs to be
retorqued.
4. Check the timing again, as well as the valve adjustment.
5. Very slowly and using the lowest rpms as possbile get to about
65mph. Put the car in 4th gear. The coast, in neutral, to about 30.
6. Go from 30 to 65, in 4th gear about 20 times. This allows the rings
to seat, so do it right, and do it 20 times.
7. Drive EASY for about 150 miles. Change the oil. Still just the
regular oil.
8. Drive easy for another 150 miles. Change the oil again. Still just
the regular oil.
(I realize that steps 7 and 8 say the same thing. Do it twice)
9. Drive it kinda easy (no trips to redline) for another 1500 miles.
10. Change the oil again. Now you can use the expensive synthetics if
you want to.
11. After that, the motor is pretty much broken in, so "go run the dang
thing to see how fast it is!!!!".
Of the 3 methods, Stephen's method of only going for 500 miles on break-in is pretty aggressive and I personally would opt for the other more conservative methods of going longer but that's me. I would personally change the non-synthetic oil more frequently than the way the Endyn method states.
These are all different methods but do you see the similarity? No one suggest beating on the car immediately. Even the most aggresive method by stephane suggested 500 mile break in.
Old May 15, 2007 | 04:47 PM
zid's Avatar
zid
Default Re: (Tam N)
these all sound like a great way to reduce power in the long run and promote the burning of oil.
This is what I did. If you drive your car hard, break it in like this. If you drive like most ppl, whatever. But breaking it in like the dealer says Ive heard will cause the engine to burn oil later in life.
http://www.mototuneusa.com/break_in_secrets.htm
Modified by zid at 11:33 AM 5/16/2007
Old May 21, 2007 | 09:49 AM
Default Re: (zid)
2nd that
SeeDeeSeven
13
Aug 12, 2007 07:26 PM
808k20z3
41
Jan 10, 2007 01:07 PM
JohnW
30
Oct 27, 2006 06:18 AM
TypeSKid
13
Sep 29, 2006 12:35 PM
040404
Apr 24, 2004 05:42 AM
