mounts
Old May 11, 2007 | 10:01 PM
eg6civic1538's Avatar
Default mounts
what mounts do i use on a ls swap into a 88-91 crx, anything that i need to know about the swap?
Old May 11, 2007 | 10:32 PM
e jay one's Avatar
Default Re: mounts (eg6civic1538)
probably gona want to search seeing as how it sounds like you know nothing. on the good side ls is the easyest swap. you need aftermarket mounts to put a b series into your crx. then you gota make a dent in the frame rail so the alternater doesnt hit it. then you gota get aftermarket shift linkage or cut and weld yourself some b series ones. oh ya if you have a dx you need to wire it for mpfi. im sure theres a bunch more little stuff like da teg hoses and da teg throttle cable but you can find that out on your own.
Old May 11, 2007 | 10:36 PM
Default Re: mounts (e jay one)
your right i dont really know anything about 88-91 civic/crx...i just wanted to try somthing new...
Old May 11, 2007 | 10:38 PM
e jay one's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6civic1538 &raquo;</TD></TR><TR><TD CLASS="quote">i just wanted to try somthing new...</TD></TR></TABLE>
put a k motor in that bitch then.
Old May 12, 2007 | 12:06 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">
put a k motor in that bitch then.</TD></TR></TABLE>
get straight to the point....
YSOFCR-VA
Oct 24, 2012 05:33 PM
Jmay258
Mar 18, 2008 10:19 AM
Youlose1305
May 18, 2006 09:06 PM
fbpem1
Apr 28, 2006 03:03 PM
