Honda S2000 Honda S2000
bout 2 do oil pan removal/install.. gettin all my procedure verified first so dont run into any dela
Old May 11, 2007 | 09:48 PM
J.nguyen's Avatar
Default bout 2 do oil pan removal/install.. gettin all my procedure verified first so dont run into any dela
bout 2 do oil pan removal/install.. gettin all my procedure verified first so dont run into any delays while in process..
oil pan coming in on monday..
so ive been researching and found this is procedure:
take off bolts, take off AC bracket taht connects to pan
remove old sealant with razor blade
spray / degrease new oiil pan with (what product? brake cleaner?)
put ac bracket onto new oil pan and put honda bond RTV evenly on it
put back on the oil pan and start from mid and work way out doing an X pattern as with lug nuts. making sure just puttin on bolts first, then using ratchet later..
(i dont have torque wrench so hand tight will be a sufficient guess?)
wait 24 hours, then put in new oil / filter.
also i hear theres 2 new bolts that were replaced in newer models.. should i get these bolts too since i have oil pan dropped anyways?
Old May 12, 2007 | 07:13 AM
Shy_GuyAP1's Avatar
You can get a torque wrench for $20 at walmart
Old May 12, 2007 | 10:12 AM
MidwestAutoWorks's Avatar
Default Re: bout 2 do oil pan removal/install.. gettin all my procedure verified first so dont run into any
instead of taking the braket off while under the car, take out the two bolts that they are attached to it and then swap that bracket while the pan is out.
unless that is what you are already saying. Its kind of hard to read.
I just did it yesterday. You will also need to take the cross brace off and the front oil pan bumper
Old May 12, 2007 | 10:46 AM
Ross 2.0's Avatar
In a Junkyard near you.
Don't worry about waiting after it's done. As long as you use honda bond just dump some fresh oil in and drive.
Old May 12, 2007 | 01:25 PM
WowOzYouRock's Avatar
Default Re: (Evil Monkey)
drain the oil first though... ROFL
nekoabandoned
Nov 28, 2005 12:21 PM
Mag00n
May 8, 2004 08:43 AM
Horatio
10
May 3, 2004 01:44 PM
Mag00n
May 1, 2004 06:09 PM
dynomax27
Oct 15, 2002 04:22 PM
