Officially the GREATEST 4TH GEN PRELUDE PART OUT EVER
My dear friends... the time has come. After my second rebuild with the h23vtec, I just can't seem to overcome the bad luck. This time around I had a valve drop on me and cause some pretty large setbacks. SO after some extensive number crunching and soul searching my choices are to sleeve it and start over or part it.....
My loss is your gain... you guys know how much work, effort, and quality parts went into this car... so take the opportunity to put a piece of my frankenstein in your lude.
PICS COMING SOON!
1992 H23Vtec JunLude:
Everything is OBO so throw me an offer... the worst that can happen is I say hell no and maybe laugh at you
m2b4 LSD tranny- $1200
Shifter cables- $150 (perfect for 3rd gen h22 swap)
Type S oversized pistons .25mm over- 3 were salvaged from the build w/ less than 200 miles on them- $100
DC header with custom 2.5in collector- $250
Euro R intake manifold (lightly ported)- $250 by itself or $500 for DSM 440's, STR fuel rail & regulator, custom plate, Hondata IM glasket, and ported throttle body.
STR fuel rail & fuel pressure regulator- $150
DSM 450cc injectors BLUETOPS- $75
ported TB- $75 or a set w/ IM
Hondata IM gasket- $50
JUN III cams, springs, retainers, Volution Racing adjustable cam gears- $1500
Hondata S100 w/ p28- $300 (pending)
Iceman intake w/ filter and all connecting pieces- $100
KTeller stainless 2.5 exhaust (mandrel bent) w/ KTeller 22in resonator (no cat)- $550 You have to see this exhaust... it's the sexiest thing on the car! also less than 200 miles on it.
MSD SCI igniton w/ MSD blaster coil & MSD spark plug wires- $300
Competition Clutch 6 puck clutch (less than 200 miles on it)- $200
14lb Clutchmasters lightened flywheel (also less than 200 miles on it)- $250
Polyurethane filled motor mounts painted black- $150
Manual steering rack conversion- $100
Forbidden short shifter- $125 (if I don't put it in my other lude first!)
Full Suspension- Neuspeed Sport Springs 1.5 inch drop & KONI adjustable shocks- $300 w/ stock replacement or $400 straight up no trade
Neuspeed front upper strut bar- $200
Neuspeed front lower sway bar-$75
DC Sports rear lower tie bar- $75
Tanabe rear upper strut bar- $75
MOMO cobra carbon fiber shift ****- $30
MOMO Race steering wheel w/ Sparco steering wheel hub- $200
VIPER alarm system- I'll have to think about ripping it out... if interested just ask
Custom Electroluminescent Gauges (plug and play) w/ all wiring and regulator- $175 add $20 to that and I'll make em all blue for ya
EL gas and water temp gauge- $25
Wingswest RS front lip (needs some love)- $250
WWRS side skirt (only one)- $50
JDM Black housing onepiece headlights (great condition)- $225 w/ bulbs & harnesses
OEM Custom taillight (amber removed) RIGHT side only- $35
OEM stock taillights SET- $125
Black front bumper turn signals- $40
Accord rear lip- $20 (the right side was cut a little too much by my exhaust shop... but if you want it its yours)
Black cloth seats (front and rear)- $150
Extra set of cloth seat covers- $25
Polyurethane motor mount inserts NIB- $50
SI Sawblades (on crappy tires)- $200
Radiator/fans- $150
complete wiring harness (very clean)- $100
Black side mirrors- $25each
Custom fiberglassed 2 gauge pillar (black)- $50
Black trunklid with spoiler- $75
Brand new black carpeting on interior trunk pieces- $40
Front crossmember w/ radius rods (cut for larger exhaust)- $150
***THe car is black so if there's any body parts you may need just let me know and I'll get pics and more details on condition and whatnot. If you need it I got it.***
As for the motor:
the h23 crank is balanced and in good shape- I'll take $200 for the crank, rods, and crank pulley
The H22 head has significant damage to intake valves and one exhaust valve seat but a highly qualified machinist said it's definitely fixable. If anyone's up for it they're welcome to it- $100
Water pump (brand freakin new)- $100
Any parts you may need from the block or head are also up for bid etc...
Manual tensioner (all parts)- $50
Axles- $175 (driver side is BRAND new)
Brembo cross drilled/slotted rotors- all 4 for $50
Valve Cover (purple)- $50 you can paint it!
Dash, knuckles, brakes, sunroof, window glass, and interior pieces are needing new homes so if you need it let me know. Most of this is still on the car so I don't have any individual pics yet. I'll see what I can do as far as taking more pics and posting them soon. This is the beginning to a long heartbreaking partout.... but it's the best of the best stuff for the 4th gen.
Ofcourse buyer pays any and all shipping...
Feel free to call me @ 678-789-9506, email me @ brittoknee@hotmail.com, or pm me here....
Thanks
PICS COMING SOON!
Radiator/fans- $150
As for the motor:
Thanks
