b16b location of throttle position sensor voltage output wire?
Old May 11, 2007 | 04:20 PM
vtecftw's Avatar
Default b16b location of throttle position sensor voltage output wire?
Hello this is for the nitrous managment unit on my motor and i am unsure of the correct wire, also the location of the tach signal wire,please let me know
thanks in advance guys
Modified by vtecftw at 5:37 PM 5/11/2007
Old May 11, 2007 | 04:36 PM
vtecftw's Avatar
come on! you guys know this
bump
Old May 11, 2007 | 10:31 PM
vtecftw's Avatar
1 AM BUMP
Old May 11, 2007 | 10:50 PM
civicsi401's Avatar
Default Re: (vtecftw)
runing the zex kit are you?
and the tach wire is the negative in the coil i believe its black and yellow
Old May 12, 2007 | 11:31 AM
vtecftw's Avatar
yes the zex kit
bump does anyone know the throttle position sensor wire
Old May 12, 2007 | 11:35 AM
sicones's Avatar
the TPS signal is the middle wire, tach output is the negative coil terminal or the blue tack output wire near the driver side shock tower/firewall
Old May 12, 2007 | 11:47 AM
vtecftw's Avatar
thank you sicones!
your help is apreciated!
vtecftw
Jun 22, 2007 04:12 PM
vtecftw
Jun 22, 2007 10:32 AM
dpw41285
Nov 12, 2004 07:25 AM
aemciv
May 8, 2003 12:54 PM
