FS:1995 honda delsol si.... alot of new parts... $3k
forsale:
171xxx miles
d16z6 stock motor ( really good conditon ) runs strong idles fine
oil changed every 3k miles with mobil 5000 10.30
spark plugs replaced about 10k ago
o2 sensor replaced about 7k ago
dx transmission ( i was told this by previous owner ) no grinds
ive been working on the suspension/brake system on this car for the past 4 months... so pretty much ill list everthing that has been replaced..
3 months ago or less
-new all 4 wheel bearings
-new all 4 brake rotors
-new all 4 brake ceramic pads
-new front calipers ( both ) ( gsr ) on 99-00 si calipers
-new 15/16 master cylinder ( upgrade )
-techna fit braided coated lines
-new lower ball joint boots
-new right axle
-rack and pinion outer boots
-new tie rods
-15 sportamax 002 rims with 195/55/15s ( bought them new and installed them when i was done with all the brake stuff)
-alot of bolts and nuts were replaced too with new stuff
a week ago old
-new tokico allumina shocks
-new h&r sport springs
-philips xtream headlight bulbs ( dope bulbs )
3 months old
-new aluminum radiator ( oem was old and with cracks )
other suspension parts that were replaced under my ownership
-front LS (22mm) sway bar
-rear delsoldohc (15mm) sway bar
-swaybar Energy suspension buhsings and endlinks
-rear SSr tie bar
-rear password strut bar
-rear DIY uppper trunk bar
-front trackion bar ( links not installed but do have them )
-rear lower control arms ( aluminum )
-safety 21 6 point cage ( i havent seen another one besides cusco )
reaplaced under my ownership
-swap the power steering system for manual steering
-took all the AC system out (heater still works)
-no more cruise control
-alarm
misc aftermarket
-quick release
-leater red stiching steering wheel
-nrg bucket seat
-2 1/4 piping ( stock muffler )
notes..
-all the suspension parts.. control arms and trailing arms were painted prior to installation ( with frame special paint )
- the interior is pretty much stripped ( i got all the panels minus rear speakers and middle rear panel )
-rear trunk empty
-diy satin black paint job ( done a year ago ) bottom of the car was also spray painted and wheel wells got a fresh coat of rubber coat
-dent on rear right quater panel ( hit and run at a parking lot )
-2 small dents on hood
-there is small squeak sound coming from the front due to the urathane ES sway bar bushings.. they need lubrication
-the driver door and the rear license plate panel was also replaced by me. ( both parts had dents done by previous owner )
got lots of pics but dont want to post all of them. serious buyers will get them and i will gladly answer any questions..
suspension parts=1500 (including the brake system, spring/shock, all other)
rims=600
cage=600
grand total of 2700 my asking price is 3100obo....
got a folder full of receipts for the parts. i also did all the work myself.. i have been taking car of the car with ALOT of care...
171xxx miles
-new right axle
-new tie rods
a week ago old
3 months old
-rear SSr tie bar
-alarm
misc aftermarket
-quick release
-nrg bucket seat
notes..
-rear trunk empty
rims=600
cage=600
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchymaster »</TD></TR><TR><TD CLASS="quote">clean title?</TD></TR></TABLE>
clean title Sr.
clean title Sr.
EFing8
15
Oct 28, 2007 07:23 PM
JCracer723
May 11, 2007 09:51 AM
