starting problems when my car sits for a while?
say in the morning or after work for a coupe hours ill go turn my car on it will turn on then shut off an it wont turn over ill check all the wires an then turns on with no problem ? could it be my plugs an wires i just did the timing beld jdm ecu an h22 type s haders now im gettin this problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97em1 »</TD></TR><TR><TD CLASS="quote">it cranks but wont turn on</TD></TR></TABLE>
I had a problem with my car like this many years ago. Turned out to be a worn out dist. cap.
When was the last time you changed it? In fact, when was the last time you changed the plugs, plug wires, dist. cap., and rotor?
Main relay.. I thought it was my plugs and wires.. Replaced that.. Now I when I go to meet up with friends I leave my car on because sometimes when I go to crank it.. it'll turn on but then it'll die off immediately.. Sometimes I can save it by revving the engine when I start it but sometimes it'll just bog down immediately.. embarassing too, I left from school early the other day.. Started my car it died off. I sat there for 30 mins.. every 5 mins i'd try to crank it over and try to save it by giving it gas.. Sucked.. but I finally got it. I believe its the main relay thats over heating? Because it only happens after I turn my car on and off a bunch of times in a short period of time.
thekatinthehat
Sep 9, 2003 08:25 PM
