Honda S2000 Honda S2000
Alignment....Anyone else not able to get the specs they wanted?
Old May 11, 2007 | 01:25 PM
m R g S r's Avatar
Default Alignment....Anyone else not able to get the specs they wanted?
So I went to an alignment shop where I know one of the guys who works there.
I went in wanting
REAR:-2.0* camber, .25" toe in,
Front:
-1.0* camber, 0" total Toe, 5.8* caster on the left, and 5.7 on the right
Wellll.....
For some reason we were only able to get the negative camber on the passanger side up to -2.6*, so I just had them make both -2.6. Wierd, because the right side went up to -2.0* just fine.....and with the front, the specs I ended up with were what the guy doing the alignment said was the best he could get. . .
Anyway here are the final specs, Prob a little aggressive for the street, but ohh well...
Rear:
Camber: -2.6* Left, -2.6* Right
Toe IN: 0.25"
Front:
Camber: -1.1* Left, -1.1* Right
Caster: 5.8* Left, 5.9* Right
Toe: -.01 Left, -.01 Right
Anyway, With these specs, is my alignment okay? Or will the tiny tiny differences such as front toe and caster mess it up? The car feels alot better than before, the numbers were pretty off when I went in there...
Ohh BTW, I'm on stock shocks and Skunk2 springs.
Old May 11, 2007 | 01:45 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Alignment....Anyone else not able to get the specs they wanted? (m R g S r)
You should be fine. Watch that toe curve.
Old May 11, 2007 | 02:05 PM
Tyson's Avatar
its because youre lowered you cant get less camber.
youre fine.
Old May 11, 2007 | 02:14 PM
m R g S r's Avatar
Default Re: Alignment....Anyone else not able to get the specs they wanted? (Mr. Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">You should be fine. Watch that toe curve.</TD></TR></TABLE>
what do ya mean?
Old May 11, 2007 | 02:41 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
ride height plays a factor with the alignment...
may i as why you went with thpse specs?
punxsk8r555
Suspension & Brakes
Aug 13, 2010 04:27 AM
deviant1
Dec 10, 2003 07:25 AM
paz92ls
Oct 17, 2003 05:18 PM
alfaaay
Mar 21, 2003 06:30 PM
keys
Sep 7, 2001 11:21 AM
