B SERIES ALL MOTOR LONGBLOCK.
Old May 11, 2007 | 12:32 PM
AFTERZERO's Avatar
Default B SERIES ALL MOTOR LONGBLOCK.
Selling for a friend of mine.
1995 gsr motor, 8k miles on the motor.
Bottom end.
b18c1 jdm itr pistons, 25 oversized.
gsr crank
gsr rods
oem honda rings, oem main bolts
oem oil pump, oem water pump toda timing belt
all new bearings and seals.
Head
2000 Type r head purchased new from Acura
real jun 3 cams
real jun cam gears
real jun valve springs retainers
supertech flat face valves
type r head gasket
arp head studs
Type r manifold
type r throttle body 66mm
310 rc injectors
aem fuel rail
ngk spark plug wires
aem pressure regulator
mugen replica valve cover
spoon sports thermostat
new obd1 distributor
The motor was put together by Pat at Factory 5 Motoring(ase certified technician)and tuned by Mikey at factory 5 on chrome.
This setup made 202whp 137tq have dyno sheet.
Before the motor was pulled out both compression and leakdown were done. Less than 5% all 4 cylinders and compression was 253 all accross.
Serious buyers Im for price will have pics tomorrow.
termite587
Sep 8, 2016 01:41 PM
OrangeTeggy
Apr 25, 2011 10:29 PM
EG6KILIN
Apr 3, 2011 08:05 AM
b20vdelsol619
Feb 2, 2010 07:37 PM
vtec15x
Mar 24, 2009 09:55 AM
