how do you turn on self diagnostic on crx 89?
how do you turn on self diagnostic on crx 89? does the check engine flash or do i look at the ecu flash. i know on the 92+ you close or pin somethin not sure on crx though thanks
pull the carpet back on the pass. side and count the flashes on the ecu. there is a whole bunch of stuff in the FAQ about ecu codes.
16yroldekownr
26
Sep 1, 2009 08:14 PM
89, check, civic, codes, crx, diagnosis, diagnostic, diagnostics, flash, honda, location, procedure, selfdiagnostic, tool
