+1mm OS valves with 11:1 high compression H22
Old May 11, 2007 | 11:52 AM
cpmike's Avatar
Default +1mm OS valves with 11:1 high compression H22
hey guys, im running an H22 euro-r. basically a type-s, as far as the 11:1 pistons and cam profiles are concerned.
ill be running the euro-r cams (type-s) for now but would like to upgrade down the line.
with a set of +1mm oversized valves (with skunk2 springs and retainers), how large of a cam should i be limiting myself to? ill be using a stock headgasket.
any input would be helpful, thanks
Old May 14, 2007 | 07:34 AM
cpmike's Avatar
Default Re: +1mm OS valves with 11:1 high compression H22 (cpmike)
oooootay.
slojdmcrx
18
Sep 5, 2018 06:59 AM
NewOrleansH22
May 7, 2005 09:36 AM
2001accord
Apr 5, 2005 11:08 PM
explosive
Nov 24, 2003 09:39 AM
