Maintainence Required Light
Old May 11, 2007 | 11:23 AM
Importn2oRacer's Avatar
Default Maintainence Required Light
My 2000 Accord's yellow "maintainence required" sign under the tachometer suddenly came on after I was doing a 275mile highway drive from Orlando to Tallahassee. It never came up before, usually it justs flashes 4x prior to starting the car but now it just stays on. And I don't get whats the difference between the Check engine light and the maintainence required light? Are they the same thing?? My check engine light is off.
Old May 11, 2007 | 11:34 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Maintainence Required Light (Importn2oRacer)
The Check Engine Light and Maintenance Required Light are different.
If you do regular maintenance such as regular oil changes, etc., you're okay. If you want to reset it, look in the Accord FAQs up top.
Old May 11, 2007 | 03:21 PM
The-Kid's Avatar
To reset. (even though i suggest the Search button) With the key off , press the select button on your gauge. Hold for 10-15 secs. Then turn your key to 2nd.(run i think) HOLD IT until the indicator goes away. Thats it. Next time you start it, it'll go away.
Old May 11, 2007 | 06:19 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importn2oRacer &raquo;</TD></TR><TR><TD CLASS="quote">... It never came up before, usually it justs flashes 4x prior to starting the car but now it just stays on...</TD></TR></TABLE>That flashing is a warning a couple hundred miles early. If you had left it those earlier times, it would have reached the point where it stays on.
This time you just went right thru those couple hundred miles...
Old May 12, 2007 | 08:32 AM
Officer's Avatar
Default Re: Maintainence Required Light (JimBlake)
mine normally comes on around oil change time. I just reset it everytime. no problems
Old May 12, 2007 | 11:11 AM
The-Kid's Avatar
Default Re: Maintainence Required Light (DailyDrivenCB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DailyDrivenCB7 &raquo;</TD></TR><TR><TD CLASS="quote">mine normally comes on around oil change time. I just reset it everytime. no problems</TD></TR></TABLE>
His is a little harder than your 91 Accord. Your Accord you just have to push the button in the gauge cluster. His is more electronic.
Old May 12, 2007 | 07:05 PM
Officer's Avatar
Default Re: Maintainence Required Light (The-Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Kid &raquo;</TD></TR><TR><TD CLASS="quote">
His is a little harder than your 91 Accord. Your Accord you just have to push the button in the gauge cluster. His is more electronic.</TD></TR></TABLE>
Your Correct my friend, i wasnt even paying attention to what his was. LOL.
rccnh
Mar 12, 2007 01:29 PM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
carlos11
Feb 19, 2005 04:03 PM
Jet Black
Aug 27, 2003 06:03 PM
Brian-Brian
Jun 6, 2003 01:49 AM
