another no start no spark (yes ive searched and checked grounds:))
Old May 11, 2007 | 08:04 AM
slaminsam's Avatar
Default another no start no spark (yes ive searched and checked grounds:))
ok first off i have a 91 hatch std that had a b16 in it and now has a ls vtec with no spark. the car ran when i pulled the motor but not now. i replaced the dizzy for the reason of the reluctor wheel clicked on the shaft. so i ordered a new from distributor king and installed it and what do you know no spark. i go through all the normal checks fuse 14 the t stat ground, the ones under the dash, the one from the valve cover to chassis and all is good. i even try switching out my old ignitor and old coil and nothing. even tried switching the white wires. I have no codes in my ecu and the dizzy wires ohm out back to the ecu. so im lost as i can be. i have to be missing something i mean whats the odds that i would get a defective new dizzy and the parts in my old one are bad?? thank you for reading my post and your input will be greatly appreciated
thanx
slaminsam
Ep1dem1c
Feb 14, 2021 06:03 PM
BarebonesB18
Feb 25, 2018 09:28 PM
smoovekriminal
Aug 17, 2007 09:55 PM
bmxbikes
Jul 13, 2007 07:27 PM
EFz6er
Aug 20, 2005 03:37 PM
