ITR front calipers onto an EH3
if you need to change the rotor you will need to change the hubs. I think.
Also do a little search there is a thread that has what stock honda pieces fit which cars. probally "official brake application chart" or something
You need the caliper bracket, which needs to be milled a bit. Then you need redrilled Prelude VTEC rotors. You'll need to change the spindle only if the bracket doesn't line up right (Integra spindles will definitely work, I don't remember if all the Civic ones do). You'll undoubtedly need more information to do this correctly, so search in the archives, I'm 10000% positive detailed write-ups are there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHDSICOUPE »</TD></TR><TR><TD CLASS="quote">I did this swap a few years ago when i worked for Honda i used 97 acura rl rotors 99 acura cl v6 calipers and pads and eg spindels with hubs and bearings from honda for a type r the rear is a lil bit tricky theres a way to use prelude rear trailing arms i just bought the rear ones from honda new </TD></TR></TABLE>
so all i'll need is the ITR calipers and pads, ITR caliper brackets, and 97 acura RL rotors?
SIReg9
23
Nov 22, 2004 08:36 PM
SilverDc2
Jun 4, 2003 07:46 AM
