Rear seats install pics
Old May 11, 2007 | 12:29 AM
Morty's Avatar
Default Rear seats install pics
Hey i was just wondering if anyone has pics or links to a website that shows you all the parts in a certain area of your car for install and part purposes...just want to see if anyone has any so i dont have to go the acura dealership...rear seat part diagram would be great. thanks
Old May 11, 2007 | 03:40 AM
MatrixShark's Avatar
Try deliii.com and download the manual.
Old May 11, 2007 | 04:11 AM
AW's Avatar
AW
Default Re: Rear seats install pics (Morty)
Rear seats is one of the easiest pieces to take a part.
a clip needs to be removed from each side on where the seat pivots(upper piece), sides closest to the panels. Then remove the clips holding the rear carpet to the back of the seats. Slide each top piece to the panel and remove by lifting up. Then one bolt holds the bottom piece in, tilt it up, pull up, tilt again and it should be free.
Old May 11, 2007 | 08:47 AM
waddy41's Avatar
so easy......u can juss figure it out..
but use the search function if u need the pics
Old May 11, 2007 | 03:48 PM
Morty's Avatar
Default Re: (waddy41)
i used the search...nothing...ppl should stop posting that comment its not helpful
Old May 11, 2007 | 03:50 PM
Morty's Avatar
Default Re: (MatrixShark)
thanks ill take a look there
Old May 11, 2007 | 04:03 PM
nholmes's Avatar
Try this:
http://www.team-integra.net/se...D=170
camelian
Aug 18, 2005 08:37 PM
mugenspoongsr
May 30, 2005 08:52 AM
-anakist-
Oct 27, 2004 07:56 AM
Miz101
Sep 17, 2003 01:22 PM
JL 74
Mar 25, 2002 08:30 PM
