96-00 hatch mini mi swap help!
Old May 10, 2007 | 09:40 PM
96civicek's Avatar
Default 96-00 hatch mini mi swap help!
sup all, i got a 96 civic cx hatch with a d16y7 stock non vtec motor and i wanna do a mini mi swap. i got a d15b vtec head i think its obd1 do u guys know if this head will work work on my car or do i have to change anything to make it possible ?? thanks
Modified by 96civicek at 11:10 PM 5/10/2007
Old May 11, 2007 | 06:16 AM
96civicek's Avatar
Default Re: 96-00 hatch mini mi swap help! (96civicek)
anyone ??
Old May 11, 2007 | 06:22 AM
97Ej6mike's Avatar
Yes it should work, but your going to need to keep your Y7 distributor, and get a wiring harness thats made for VTEC, and also because the Y7 uses a different platform for the IACV, its a 3 wire plug on the y8, where as on any other manifold ( assuming your using the D15's manifold) its only a 2 plug.
Your going to need to swap manifolds as well because the ecu's for VTEC all use the standard manifold that uses 2 plugs for the IAC, plus their designed better
Old May 11, 2007 | 04:38 PM
96civicek's Avatar
ight kool thanks
dirvin7588
Apr 17, 2011 07:53 PM
pinche
Dec 13, 2004 01:03 AM
97DX
Nov 21, 2002 08:06 AM
