ABS crap
Old May 10, 2007 | 08:48 PM
iceman7329's Avatar
Default ABS crap
I moved the ABS module in the trunk to make room for my amp rack today. I just flipped it to the other side of where it was mounted. Ever since the ABS has been flickering, I know what I did to cause that. So I just unplugged it and the ABS light went off and my brake pedal no longer goes to the floor once I stop like it has been doing ever since I got the car.
So, my question is what causes my brake pedal to sink to the floor once I stop? It will also hit the floor if you slow down over a very long distance. When the ABS module is unplugged it doesnt do this. I did get an ABS light once when I first got the car but it only came on once.
Old May 10, 2007 | 08:52 PM
97Ej6mike's Avatar
May be low on fluids, i woudlnt be messing with the ABS module, that will certainly affect your pedal feel if you are tampering with it.
Old May 10, 2007 | 09:12 PM
iceman7329's Avatar
Default Re: (97Ej6mike)
The fluid is fine. The pedal feels normal now and the car stops as it should with the ABS disabled.
hondaboy4life
Dec 28, 2007 09:48 AM
SpeedFreek34
Jul 22, 2007 05:43 PM
jonzel
Jul 27, 2005 03:29 PM
Audio28
Dec 22, 2002 11:48 PM
DC5 Type-R
Mar 8, 2002 05:52 PM
