type-r vtec engagement point?
Old May 31, 2002 | 09:40 AM
dubnine's Avatar
Default type-r vtec engagement point?
i just plugged a 2001 type-r ECU into my 99 SI and vtec isn't kickin in untill 6000. Is that how typ-r's are? power below vtec very weak, feels like i'm back to a b16 motor....
Old May 31, 2002 | 09:44 AM
MPH's Avatar
MPH
New User
Default Re: type-r vtec engagement point? (dubnine)
Stock for a R is 5700 @ wot.
Old May 31, 2002 | 09:52 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: type-r vtec engagement point? (MPH)
I'm just picking nits but I thought it was 5800.
Old May 31, 2002 | 10:05 AM
Jeff Lawrence's Avatar
Default Re: type-r vtec engagement point? (newt2)
Doesn't come on for me that I notice till 6k or so on the tach
Stock tach sucks though
Old May 31, 2002 | 10:07 AM
slash00R's Avatar
New User
Default Re: type-r vtec engagement point? (Jeff Lawrence)
5700 WOT
5900 otherwise
Old May 31, 2002 | 11:03 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Your car feels weak before vtec because it is weak before vtec. Not to sound like a dick but what did you think a ITR ECU was going to magically make up for the fact that you have the weakest Vtec B-series motor from Honda.
Unless you have more in your motor then just bolt ons (Which if you do then give us the full story so we can help you) your car will feel like a regular B16A.....period. No stock Honda ECU will change that (Well besides the Vtec X-over).
Old May 31, 2002 | 11:30 AM
rbf351's Avatar
Default Re: type-r vtec engagement point? (Apex i ITR)
i have a 2000 Si with a CTR ecu. i also have the cams, JDM ITR header, ITR intake manifold, ITR valve springs, and ITR AEM CAI
my crossover is until 6200 rpms. i thought i was the dash(2000 ITR cluster) but i plugged in a 6200 rpms pill into my shift light and it's accurate. is that the way it's supposed to be? also my rev limiter is 9100 rpms. i put a 8800 rpm pill to check it and it lit up when the dash hit 8800 rpms, so it's not the dash being off
Old May 31, 2002 | 11:45 AM
Tommy_Gunns's Avatar
Uh...the ITR ECU is designed for a 1.8 litre motor. If you are using it on a B16 motor, you'll be giving it too much fuel.
Old May 31, 2002 | 11:57 AM
98R #448's Avatar
Default Re: type-r vtec engagement point? (Tommy_Gunns)
that was pretty good info tommy_guns
Old May 31, 2002 | 12:54 PM
dubnine's Avatar
did you read my post right???? "it feels like i'm BACK to a B16 MOTOR" and before you go asuming stolen type-r give me your e-mail and i will scan the salvaged integra title in my own name and send it to you....
So this is the type-r feel, little low end power, but everything you want above 6 grand.... it ran good for city driving with the b16 ecu you don't have to beat on it as much to get it going some, i love beating on it now though with ITR ECU...
Old Mar 11, 2003 | 07:03 AM
SuperMan19's Avatar
New User
Old Mar 11, 2003 | 07:06 AM
Chris N's Avatar
Why would you put an itr ecu in your 99Si? That makes no sense right there.
It is designed for a b18c, which you don't have.
What do you mean? 'feels like I'm back to a b16 motor', you said you put an ecu in only!
Stock tachs are off, vtec kicks in at 5700.
Also, an itr ecu is not going to make you any power, just dump too much fuel on your b16.
Edit: maybe you should have told us what engine you had in the car, since it doesn't state it anywhere in the post.
BTW - This thread is f-ing retarded. If you don't know the vtec xover point and can't find it in the search, maybe you shouldn't be using this site at all. It is one of the easiest pieces of information to find out, like asking the CW paint code or engine code.
[Modified by Chris N, 10:07 AM 3/11/2003]
SuperMan19's Avatar
New User
from your post, it sounds like you mean you have a 2000 SI B16 motor and all you did was change the ECU. Anyone agree? Or did you mean that you have the whole swap from an ITR and you're running the ITR ECU too and that it feels weak down under vtec?? I only drove a type R once and didn't step to vtec so I dunno. Motor is loud as heck though
Old Mar 11, 2003 | 07:09 AM
Chris N's Avatar
Default Re: type-r vtec engagement point? (SuperMan19)
He said he put an ITR ecu in his '99 Si.
Nowhere did he say 'swap' and 'ecu' together.
Then he gets pissed at us since he can't create an informative, intelligent post.
This is the dumbest thread in a string of very dumb threads that have been popping up lately.
Old Mar 11, 2003 | 07:16 AM
ajchen's Avatar
Default Re: type-r vtec engagement point? (Chris N)
easy buddy.... some people arent as articulate as they should be on the net...
i agree - the search function needs to be used more often. but its a public board... new people will be logging on all the time and learning lots of "newb" info.
we were all there once
[Modified by ajchen, 4:16 PM 3/11/2003]
Old Mar 11, 2003 | 07:19 AM
Chris N's Avatar
I'm always ready to attack, Andrew!
He got crazy first. It's amazing to me that he is going to fly off the handle after not giving us any good info.
Search is pretty good here, I almost always find what I am looking for.
But, most people probably just try the first thing that comes to their mind, can't find what they are looking for, and don' t bother to try the archives, or different search word combinations.
oh well. Darwin is coming....
Edit: 291 days, been here longer than me. He ain't no newb.
[Modified by Chris N, 10:20 AM 3/11/2003]
Old Mar 11, 2003 | 07:37 AM
ajchen's Avatar
2 words for ya:
P--- W----
Old Mar 11, 2003 | 08:52 AM
Dave-ROR's Avatar
Yes, we read your post correctly. You, however, failed to write it correctly. How in the hell are we supposed to know that you meant you had an ITR motor when you stated that you plugged in an ITR ecu into your 99Si?
-Dave, who is not a mind reader.
Old Mar 11, 2003 | 09:22 AM
SurferX's Avatar
LOL, I think everyone is talking to nobody. This post is almost a year old, the guy probably isn't even here anymore.
Old Mar 11, 2003 | 09:24 AM
TypeR 01 886's Avatar
Default Re: type-r vtec engagement point? (SurferX)
r u serious... it came back from the dead?!?
Old Mar 11, 2003 | 09:37 AM
Dave-ROR's Avatar
lol on the rest of us. why did someone bring this thread back?
Old Mar 11, 2003 | 09:42 AM
io_burn's Avatar
New User
Default Re: type-r vtec engagement point? (FyrStarter)
Guys what's the CW paint code, do black R's exist, and should I use synthetic or normal oil.
thx
Old Mar 11, 2003 | 09:59 AM
Dave-ROR's Avatar
Default Re: type-r vtec engagement point? (io_burn)
thx
1. UARGEY-0
2. No, only purple and CW.
3. Neither, use ****
Old Mar 11, 2003 | 10:02 AM
io_burn's Avatar
New User
I used to run **** in my old CRX. That **** ran smooth, gained like 40whp on the butt dyno.
Old Mar 11, 2003 | 10:15 AM
Chris N's Avatar
Wow, 40whp on the buttdyno. Are you that kid with the flabby butt flaps on the Oblongs??
Why did someone bring this thread back from the dead? Wierd.....!
