Tips on buying a CRX shell
Old May 10, 2007 | 05:11 PM
Tam N's Avatar
Default Tips on buying a CRX shell
Im going to check out a couple CRX shells in the area this weekend. Are there any common problems I should be on the look out for? Is rust a big problem?
Some of these cars have their registration tags (CA) expired for more than 2 years now. Will I be force to go to a state ref for smog? I think the overdue fees will be about 100 bucks. Any other hidden cost I should know about?
Thanks
note: socal area
Old May 10, 2007 | 05:17 PM
garageEF's Avatar
Default Re: Tips on buying a CRX shell (Tam N)
rust shouldnt be a problem in your area.
check the wiring....wiring can be a PITA
Old May 10, 2007 | 05:41 PM
jdmpnoy89's Avatar
check if all the body lines are even..imo i'd rather pay the extra cash to buy a car with a straight chassis
Old May 10, 2007 | 05:57 PM
The Grimace's Avatar
Make sure it hasn't been repainted 1000 times... and that if there is bodywork done to it make sure it was done properly.
Old May 10, 2007 | 05:59 PM
Tam N's Avatar
Default Re: Tips on buying a CRX shell (jdmpnoy89)
Whats the cheapest way to tow the car? No one I know has a truck
Anyone know about smog and expired tags? state ref?
Thanks, I'll double check the wiring hardness and body for sure.
Old May 10, 2007 | 08:15 PM
menappi's Avatar
straight body, clean interior, rust, cracks, bends in any frame components, cracked windshields. I all depends on the quality 'shell' you want. Find someone with a hitch and renta dolly, otherwise your gonna need to call a towtruck.
Old May 10, 2007 | 08:46 PM
hafftrak's Avatar
Get an AAA membership. I have used mine many times to haul around parts cars.
goofball123321
May 17, 2003 01:37 AM
ongking
Apr 20, 2003 08:14 AM
GroundZer0
Aug 12, 2002 12:09 PM
