LVLP Paint Guns
Old May 10, 2007 | 01:02 PM
DesioMedia's Avatar
Default LVLP Paint Guns
Hi,
I've been wanting to paint my car for a while and keep debating between the $50 and just sucking it up and buying every thing I need to do it right. The only thing that is keeping me from going out and buying a 10 CFM compressor, guns, and compressor is $$$$$. I just can spend $400 on an air compressor that I'm going to use 3 or 4 times (max out put). I recently discovered LVLP paint guns that can use as little as 3cfm. Are there any reasonable LVLP guns out there that only need ~5cfm. I dont want to spend more than $120 on a gun.
In addition I found this LVLP for CHEAP! but it probably shoot like ****. Any advice?
http://stores.channeladvisor.c...400GB
Old May 10, 2007 | 02:14 PM
WihaSi's Avatar
Default Re: LVLP Paint Guns (DesioMedia)
My only advice is to get a good HVLP gun for clear coat. For base coat and primer you don't need a super expensive gun, but you do want a good gun for your clear. I have a SATA Jet 2000 RP Digital gun for my clear coat, it's awesome, but it'll run you like $500. I'm in the same boat you are with a compressor, I used to do body work and paint in a shop, now I'm in the office writing estimates...needless to say I want to paint real bad, and need a compressor
Old May 10, 2007 | 09:41 PM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
Default Re: LVLP Paint Guns (WihaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WihaSi &raquo;</TD></TR><TR><TD CLASS="quote">My only advice is to get a good HVLP gun for clear coat. For base coat and primer you don't need a super expensive gun, but you do want a good gun for your clear. I have a SATA Jet 2000 RP Digital gun for my clear coat, it's awesome, but it'll run you like $500. I'm in the same boat you are with a compressor, I used to do body work and paint in a shop, now I'm in the office writing estimates...needless to say I want to paint real bad, and need a compressor </TD></TR></TABLE>
im in the same boat as you. i use to paint and own a few sata and iwata guns myself but now sit my *** in the office writing estimate and calling insurance people all day
Old May 10, 2007 | 09:42 PM
vsmhatched's Avatar
yeah, you cant really cheap out on guns, you'll be able to tell in most finishes if cheap products were used
Old May 11, 2007 | 06:08 AM
WihaSi's Avatar
Default Re: LVLP Paint Guns (2'z kuztoms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2’z kuztoms &raquo;</TD></TR><TR><TD CLASS="quote">
im in the same boat as you. i use to paint and own a few sata and iwata guns myself but now sit my *** in the office writing estimate and calling insurance people all day </TD></TR></TABLE>
Kinda drives you nuts doesn't it lol! It's not bad, I like writing estimates, but damn do I wanna paint something...
Old May 11, 2007 | 09:56 PM
DesioMedia's Avatar
I guess I wasn't clear in my first post. I'm looking for cheap, good, spray guns that can be used with a 6 cfm compressor.
I also found this Titan "low air" HVLP. It only uses 4-7 cfm.
http://www.spraygunworld.com/p...0.htm
4doorpowa
Paint and Body
Jan 10, 2011 03:22 PM
99bbcivic
Paint and Body
Sep 7, 2010 09:36 PM
slacks
Paint and Body
May 17, 2008 06:15 PM
IOSUA
Paint and Body
Jan 3, 2008 09:43 PM
K20A_EH
Paint and Body
May 23, 2007 12:15 PM
