JDM B18C5 specs
Hello honda friends,
Can anyone confirm the JDM type R B18C specs for me? I noticed a lot of companies selling JDM ITR motors posting diff. specs for this motor? Ive seen 11:1 or 10:8 compression ratio and ive seen diff. HP numbers from 195 to 210? They say the 98 and up motors include a 4 to 1 header and shorter gearing for the tranny, but cant confirm the power numbers? Thanks in advance!
Modified by all boost at 6:23 PM 5/14/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all boost »</TD></TR><TR><TD CLASS="quote">Hello honda friends,
Can anyone confirm the JDM type R B18C5 specs for me? I noticed a lot of companies selling JDM ITR motors posting diff. specs for this motor? Ive seen 11:1 or 10:8 compression ratio and ive seen diff. HP numbers from 195 to 210? They say the 98 and up motors include a 4 to 1 header and shorter gearing for the tranny, but cant confirm the power numbers? Thanks in advance!</TD></TR></TABLE>
The JDM Type r motor (B18c5) ..is rated at 195hp @ 8000 rpm..... 130 lb/ft @ 7500 rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wildcat98 »</TD></TR><TR><TD CLASS="quote">
The JDM Type r motor (B18c5) ..is rated at 195hp @ 8000 rpm..... 130 lb/ft @ 7500 rpm</TD></TR></TABLE>
Incorrect grasshoppa'. There is no such thing as a JDM B18C5.
To the original poster... Your signature hurts my brain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL »</TD></TR><TR><TD CLASS="quote">
That and his HP figure is off for a JDM ITR engine. Boy is info on here going to **** lately.
OK... ok... so now i know that there is no such thing as a B18C5 JDM motor! But I still want to buy a JDM ITR motor for my USDM Type R and want to know if the JDM one is much better than the USDM one? and NO, i dont have a ITR motor for my car, so im researchin for now...... thank you for those that want to help! BTW how do you know if there is a 2.0L B18C out there? stamping or marking?
To the original poster... Your signature hurts my brain.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all boost »</TD></TR><TR><TD CLASS="quote">Do it fast, Do it furious!
but dont do it fast & furious
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all boost »</TD></TR><TR><TD CLASS="quote">BTW how do you know if there is a 2.0L B18C out there? stamping or marking?</TD></TR></TABLE> it came from the factory in japan stamped b18c5(unlike the reg jdm itr motors marked b18c) and it also had the rare oem green valve cover, those from the factory are rated at 268 whp 180 lbs trq, but they also cost about 1500 dollars more than the b18c type r swap
</TD></TR></TABLE>but dont do it fast & furious
I beg to differ but my JDM b18c5 makes 285whp with 310ft lbs of torque completely all motor. I get no traction so I have to replace the Musimoto ZX tires with Mushimoto XYZ tires, and a Motec system exhaust complete with bearings and rotary pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">They were not "rotary" pistons, they were "oval" with dual connecting rods as shown in this Honda picture.
Notice the type-r coating on the piston skirts!
I was gonna go this route too!! But the 32 valve cylinder head was out of my budget. I was bumming too, because revving to 14,000 rpm is the $hit!!!
</TD></TR></TABLE>I was gonna go this route too!! But the 32 valve cylinder head was out of my budget. I was bumming too, because revving to 14,000 rpm is the $hit!!!
Reminds me of the good old Honda NR750 blunder.
</TD></TR></TABLE>Reminds me of the good old Honda NR750 blunder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Ash »</TD></TR><TR><TD CLASS="quote">
Reminds me of the good old Honda NR750 blunder. </TD></TR></TABLE>
didnt the nr750 only had 6 valves?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itRspec »</TD></TR><TR><TD CLASS="quote">
didnt the nr750 only had 6 valves?</TD></TR></TABLE>
Nope. 32V 750cc V4. Cost 50-60k in '92 which was just silly.
Notice the type-r coating on the piston skirts! </TD></TR></TABLE>
THATS why my rings didnt fit on my other pistons i accidently orderd the jdm 2.0 b18c5 ones instead of the b18c,
on me
did the OP find everything he needed in this thread? ay more questions
on medid the OP find everything he needed in this thread? ay more questions
I just wanted specs on a JDM ITR motor, tranny, and ecu......... now i dont know where to look without getting false info before i buy? Comp Ratio? HP? is the ecu obd2a or b?
This threads hilarious!
96-97 B18C has less hp and a different header (4-2-1) than the 98+ B18C (4-1). The 98+ also had shorter gears. Besides the OBD difference everything else is minor.
For registration purposes the B18C5 would be easier to pass as it actually came with the car. Just make sure you get your car model year or newer.
haha, to the OP they are just messing with you, it happens with noobs. we have all been noobs at one point
there are differences between the motors, but it isn't something that is going to make a dramatic difference, well, besides the final drive in the tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all boost »</TD></TR><TR><TD CLASS="quote">I just wanted specs on a JDM ITR motor, tranny, and ecu......... now i dont know where to look without getting false info before i buy? Comp Ratio? HP? is the ecu obd2a or b?</TD></TR></TABLE>
comp ratio: JDM 11.1 USDM 10.8
HP: slightly higher in the JDM motor, not going to notice a difference
ECU: depends what spec motor you get
just get it from hmotorsonline.com and call it a day
Having recently bought a car I couldn't register in my home state, I'd be more worried/interested in how I was going to pass emissions (depending on whether that's an issue in your locale).
With respect to your actual questions, I'd do some more searching/reading instead or call a few of the sellers of the motors, and form an opinion from the info you find.
I still think you need to get some of those oval pistons, though.
LOL....... thanks guys! Much helpful needed info! Ill upload some pics ASAP, yes Im am a recently registered Honda-tech noob, but as far as my HONDAS, i am a veteran of the game.........
400 hp turboed B16 92 EG (drag)
320 whp turboed B18C1 powered 00 type R (track)
150 hp CBR 929 (bring it)
06 Ridgeline sittin on 22" (snow and tow)
..... I will post pics soon! Thank you all for your help...... im putting the R back to the way it was meant to be.....NA
The JDM ITR motor has a comp ratio of 11:1, if you buy a 96-97 model it is OBD2A, the 98 and up model (I don't know when they stopped production) is OBD2B. The 98 spec has 4-1 headers and gruntier cams which provide it with a smidgen more torque and hp. I can't fill you in on the gearbox sorry as I'm not a specialist on that sort of stuff. I have a 1997 JDM DC2R here in NZ and the stamping on the block says B18C, not B18C5 or B18CR.
If you'd like anymore info on the motor pm me.
