Car keeps shutting off then starts right up again
Old May 10, 2007 | 11:42 AM
stwano's Avatar
Default Car keeps shutting off then starts right up again
ok, i have a stock 93 civic ex, and ill just be cruising and my car would just shut off out of nowhere. then i would pull over to the side then it would start right up??? Sometimes it would take a while to start. I changed the main relay and distributor and that didnt fix it. What could it be???
Old May 10, 2007 | 11:58 AM
Bakeoff's Avatar
sounds almost like you have a fault ignition switch....
Old May 10, 2007 | 12:00 PM
HCJDM1's Avatar
Default Re: (Bakeoff)
was it a new or a used distributor ... are you getting and CEL's ... i had that same problem and it was in the dizzy ...
Old May 10, 2007 | 10:11 PM
stwano's Avatar
Default Re: Car keeps shutting off then starts right up again (stwano)
no CELs and I only changed the ignitor in the distributor???
DirectoryDude
Mar 26, 2012 04:55 AM
Dwizzy
May 5, 2009 08:45 AM
xkrntamax
Mar 23, 2007 10:14 AM
gsober
16
Dec 28, 2006 07:41 AM
jsou
Jul 5, 2005 02:26 PM
