air conditioning only cold while accelerating?
Recently my a/c only gets cold while I'm accelerating. At a stop signs it gets warm pretty quick. The car is a 96' Accrod EX-V6. Does anyone know what the problem is? Does it need more freon?
-B
-B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown383 »</TD></TR><TR><TD CLASS="quote">I have never recharged the a/c system and how would I check to see if the a/c fan is kicking on? Thanks for the speedy reply!
-B</TD></TR></TABLE>
Turn your a/c on and open your hood up. You will see and here the a/c fan run.
Someone on another forum asked me to check the a/c fan clutch. How would I go about doing that and how would I check to see if the charge is low?
-B
-B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown383 »</TD></TR><TR><TD CLASS="quote">Someone on another forum asked me to check the a/c fan clutch. How would I go about doing that and how would I check to see if the charge is low?
if it's low then you have a leak. Look into that first....
i wouldn't jump right to a leak, since he said he has never recahrged it, and its a 96...eventulay you have to recharge it no matter what. i would look into the recharging idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak »</TD></TR><TR><TD CLASS="quote">i wouldn't jump right to a leak, since he said he has never recahrged it, and its a 96...eventulay you have to recharge it no matter what. i would look into the recharging idea
Freon does not evaporate or dissapte in any way shape or forum. if you have a completely sealed AC system then it will last forever. However a leak will always develop. Some leaks are so minute that it would take around 5 years to completely empty the system,while others will do it much quicker.
</TD></TR></TABLE>Freon does not evaporate or dissapte in any way shape or forum. if you have a completely sealed AC system then it will last forever. However a leak will always develop. Some leaks are so minute that it would take around 5 years to completely empty the system,while others will do it much quicker.
Well you can take it to a shop or do it your-self. You need AC dye and an ultra violet light. Inject the dye into the low side then cycle the system for a day or two. Use the light to find the leak afterwards. Sometimes it is almost impossible to find in which case you will need a "sniffer" This is a tool that detects freon an emits a beeping sound when the source of the leak is located.When used together these methods are guaranteed to fing the leak.
ac, accelerating, accelerte, air, aircon, car, cold, colder, conditioner, conditioning, gas, pressed, symptoms, warm, works
