Possible bent wheel?
Old May 10, 2007 | 09:08 AM
ZexyAccord's Avatar
Default Possible bent wheel?
So i had a little mishap today, i underestimated my speed and jumped the curb by accident at about 40mph on the exit. I did a little off road action, thank god i didnt lay down the bike and after that i got back on the road and proceeded to where i was going. The bike doesnt seem to shake at 25mph i was going after the exit but just now during my lunch break i took it out up to 45mph and i dont know if its me just being paranoid but i think i sense some vibrations. The front rim doesnt look to be bend by looking at it so is there some type of machine at the bike shop that could check my wheel to make sure its perfectly straight? WHat would be the cheapest solution to make sure I'm ok and safe to ride?
Old May 10, 2007 | 09:55 AM
MSchu's Avatar
My Name is Nobody
Default Re: Possible bent wheel? (ZexyAccord)
get the front end off the ground and spin the front tire vigorously, hold a screw driver or other straight edge against the forks somewhere at the point where the rim intersects it... this is your gauge, it will be EASY to tell the rim is dented, out of round, has run out, or is wobbling... More than likely your tire is toast
Old May 10, 2007 | 10:48 AM
ZexyAccord's Avatar
Default Re: Possible bent wheel? (MSchu)
i need to replace the front tire anyway, when they put the new tire on the rim would the shop be able to check the condition of the rim to make sure its good?
Old May 10, 2007 | 12:13 PM
MSchu's Avatar
My Name is Nobody
The ONLY true test for aluminum stress/cracks is a Zyglow test, and your not going to pay for that. Have a good look around for cracks and don't trust someone else with your safety. do the test I told you about. this wont be a guarantee, but you can detect bends etc as explained above... The straight edge/screw driver is taking place of a run-out dial indicator... if you have one of those (harbor freight) your good to go in as far and dents and bends.
Old May 11, 2007 | 02:05 AM
Luke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZexyAccord &raquo;</TD></TR><TR><TD CLASS="quote"> WHat would be the cheapest solution to make sure I'm ok and safe to ride?</TD></TR></TABLE>
TBH if the new tyre won't balance then you will need to take it to step #2. Otherwise dont worry about it. Road wheels are pretty tough. Also sensingvibrations is different to feelilng, seeing them
Old May 11, 2007 | 05:13 AM
ZexyAccord's Avatar
Default Re: Possible bent wheel? (Luke)
Thats true, i think i was more paranaid and scared kind of expecting vibrations after my little jump but after work i took it home on perfectly paved back roads and it felt fine. I even got it up to 80 to make sure there is no vibrations at higher speeds and it felt normal. I think i got off easy from this one, could have been a lot worse. Let this be a lesson for me not to take 25mph exits at 65mph
Honda Motorcycles
Sep 19, 2008 11:35 AM
05CBR600RR
Honda Motorcycles
14
Jan 11, 2006 11:23 AM
green98civic
Honda Motorcycles
May 26, 2004 10:41 AM
Nextelbuddy
Honda Motorcycles
12
Jul 15, 2003 06:20 PM
HX_Guy
Honda Motorcycles
Apr 18, 2001 08:12 AM
