Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
DIY - Install 2007 Euro-CTR Shift Boot
Old May 10, 2007 | 06:33 AM
blue rocket's Avatar
Default DIY - Install 2007 Euro-CTR Shift Boot
2007 Euro Civic Type-R Shift Boot install
Part #: 77298-SMT-E01ZA
Install time: 30 mins.
Pre-Work:
-Remove shift ****
-Pull up on the aluminum-look shifter base by grabbing from the inside (left and ride inside portions) -- boot assembly will pop off.
New boot next to old boot & assembly
Another pic, notice it uses a different clip inside the boot to attach the the Euro-R shift ****
So... unscrew the four screws from the stock assembly, remove the staples holding the boot on the the assembly and remove the stock boot.
Remove the staples from the Euro-R boot and detach the little loops, the CTR boot will pop off.
Pull the CTR boot over the stock assembly (its a bit smaller so it might be a little tight). I cut a few slits in the extended pieces of the CTR boot and slipped them over the sections where the screws go. I also taped up some sections inside the boot, once you have it secure reattach it to the aluminum-look shifter base.
What it looks like after its re-attached.
From this point you can re-install if you want, but i didnt like the clip on the CTR boot, so i replaced it with the one from the Stock Si boot.
Cut the zip tie off and pull the clip apart.
The two pieces removed from the CTR boot. (wont need these again)
Remove the stock piece buy cutting the zip tie that's holding the stock Si clip to the boot.
Slide the new clip into the CTR boot, as low as you want...the lower you install it, the less "extra material" will bunch up when you reinstall the boot).
Instead of using a zip tie, i used a baggie-tie type of tie (pulled it tight around the clip and twisted), when i used a zip tie you will see a bulge from the little nub where the tie goes through to tighten.
Si clip installed on CTR boot.
another view of Si clip on CTR boot.
Reinstall and enjoy!
If you have any questions, let me know, i know my descriptions werent that great...and i should have taken more pics... Either way, this boot is HOT!
Old May 10, 2007 | 06:35 AM
06BlackSi #45's Avatar
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (blue rocket)
Yes it is! GOt the part number, but where do you order it at?? Thanks
Old May 10, 2007 | 06:36 AM
originalg00kster's Avatar
thats sick pete. you just order from dealer?
Old May 10, 2007 | 06:41 AM
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (originalg00kster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by originalg00kster &raquo;</TD></TR><TR><TD CLASS="quote">thats sick pete. you just order from dealer?</TD></TR></TABLE>
Sure can...any dealer located in the UK! I got it from a place called Lings...i was emailing all sorts of Honda dealers in the UK! lol
Old May 10, 2007 | 06:42 AM
Nighthawk R18's Avatar
Old May 10, 2007 | 07:09 AM
ednksu's Avatar
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (Nighthawk R18)
this thread has the stink of a group buy all over it
Old May 10, 2007 | 07:16 AM
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (ednksu)
uh oh, what did i start!!!?
Old May 10, 2007 | 07:17 AM
hyogen's Avatar
what are you selling your JDM type r shift boot for. you have one right?
Old May 10, 2007 | 07:29 AM
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (hyogen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyogen &raquo;</TD></TR><TR><TD CLASS="quote">what are you selling your JDM type r shift boot for. you have one right? </TD></TR></TABLE>
nope, only had my stock boot till now.
Old May 10, 2007 | 07:36 AM
singlevtec95's Avatar
Nice boot!
Old May 10, 2007 | 08:06 AM
MonkeyConQueso's Avatar
I'm in for a group buy if we can get something set up. That thing is sexy and would go with my seats wonderfully!
Old May 10, 2007 | 08:17 AM
faster Type R's Avatar
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (MonkeyConQueso)
oooo...i like! im in for a group buy!!!
Old May 10, 2007 | 09:06 AM
97Ej6's Avatar
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (faster Type R)
It looks awesome
Im in if we can get a group buy going.
Old May 10, 2007 | 09:18 AM
L-Dawg's Avatar
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (97Ej6)
Questions:
1. Is that leather?
2. Do you know how much the circuithero weighs?
Thanks man!
Old May 10, 2007 | 09:34 AM
tone*def's Avatar
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (L-Dawg)
Count me in for group buy too...... dang that thing looks sick
Old May 10, 2007 | 09:55 AM
FBPSidan's Avatar
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (tone*def)
IM IN!
Old May 10, 2007 | 10:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-Dawg &raquo;</TD></TR><TR><TD CLASS="quote">Questions:
1. Is that leather?
Thanks man!</TD></TR></TABLE>
1 - I dont know what it is, but it's thicker than stock, seems to be the same material that the steering wheel cover is.
2 - according to them it's the heaviest **** on the market...(it's heavy)
3 - group buy would be cool, but i dont want anything to do with it...it took me long enough to find a place that would even get it for me. Dealing with places outside of the US isnt all that easy.
4 - I ordered it through a place called Lings, since i know everyone is asking.
5 - You might be better off waiting for the CTR FD2 boot, since it will be a direct replacement piece
Old May 10, 2007 | 11:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue rocket &raquo;</TD></TR><TR><TD CLASS="quote">5 - You might be better off waiting for the CTR FD2 boot, since it will be a direct replacement piece</TD></TR></TABLE>
Hm, true that. Although, impatience is a virtue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue rocket &raquo;</TD></TR><TR><TD CLASS="quote">4 - I ordered it through a place called Lings, since i know everyone is asking.</TD></TR></TABLE>
http://www.bestpricehondaparts.com/ is the link...I think. Doing a bit of poking around
Old May 10, 2007 | 11:34 AM
Blk06Si's Avatar
Yeah the FD2 shift boot and shift **** is already on sale. Nice DIY and shift boot
Old May 10, 2007 | 11:39 AM
Default Re: DIY - Install 2007 Euro-CTR Shift Boot (Blk06Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk06Si &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the FD2 shift boot and shift **** is already on sale. Nice DIY and shift boot </TD></TR></TABLE>
where @?
Old May 10, 2007 | 11:44 AM
(http://www.jdmland.com/ - do a search for FD2, and click on the **** or boot.)
I don't know about the FD2 boot. I think I actually like the boot displayed here better. Although, the **** from the FD2 needs to find a way into to my car...
Old May 10, 2007 | 12:09 PM
Demonis's Avatar
Looks good but i think i like the flat black with red stitching someone had on an earlier post.
Old May 10, 2007 | 12:13 PM
Default Re: (Demonis)
You mean this one?
Old May 12, 2007 | 07:05 AM
Ricky1197's Avatar
looks great pete
Old May 13, 2007 | 09:41 AM
L-Dawg's Avatar
With the circuithero you don't have to use the nut at the base of it, correct? Just tighten it all the way on?
Thanks!
